sorry its a livernois stg I
224/230 .581 .590 114
runs great but somthing is off...I'll make a post
got a 04 suburban that i just put an LS6 in it and will be getting a century level 4 trans this week so the tune can be finished, but down the road it might see a supercharger
04 ECSB Silverado 5.3
Custom CAI
3" Single Exhaust Magnaflow race muffler
Servos
TCC and shifting tons better (some Tranny TM left since i have VHO wheels)
Tuned on AEM WB (VE and MAF) 13.5 AFR
Trying to finish getting what seems to be false knock retard gone. Anyone else have this issue
Then ill get PE Tuned
'04 Silverado
LM7 5.3
4L60E & 3.42
Stock Heads & Cam
CAI, 160* T-stat & '05 Efans
Dynatech LT System w/. Corsa Touring
Soon to be added:CircleD 258mm 2600 Stall & FLT Level 7 trans
Current tune was done locally some yrs ago & is not up to date w/. mods. I don't have any idea on what stock 5.3 settings should look like. I know tuner took out all TQ Mgmt & removed speed limiter. All else is ...
Just got started tuning, have not done anything yet except for a few things.
Speedo adjusted for staggered tires using info from this forum. Also tuned for '05 Efans. I know it's along road but here I go.
2001 GMC Sierra 1500 SLE 5.3L
2008 GMC Sierra 1500 LE 5.3L
Got my 08 tuned by some moron who said he was a pro and now am slowly fixing the problems he induced.
One problem is that my truck knocks when using 89 or 91 octane unleaded gas and runs fine with super 93 octane gas. I guess it was not so bad because it is forcing me to learn a lot.
05 SSS - Gettin ready to order software!!
- Built Not Bought -
2005 Silverado SS - Garage Whore
2003 Dakota R/T - Daily D
2003 Chevrolet Silverado SS
L92 Heads/ L92 Truck Intake
OBX LT Headers
Custom Ridings 3200 Stall Converter/Built Trans
6 Piston ZO6 Brakes/ 2 pc 15" Front rotors
Itll be here wednesday!
04 rcsb silverado 4.8 ported throttle body 3inch magnaflow tuned by a friend soon to be by me
'98 Chevy K2500
7.4L with retrofitted ZFS6-650 six speed
4.11 gears
Shorty headers
Full 3" dual exhaust all mandrel bends with Hooker aero chamber mufflers
30lb injectors(mistake)
Mallory HyFire 6A Ignition
96 K1500, Bought hpt to go along with my 0411 PCM swap. Also to help with my Cavaliers, But mainly for the truck.
09 GMC Sierra SLT 4wd 4dr.... L9h 6.2l Flex Fuel..........Tuned by me....
Hi all,
I just got my HPT recently so I can learn to tune my '09 Sierra Vmax, I'm glad I found this post! So far I've down loaded version 2.23, done the first read,the first log, & I'm currently doing my first edit using what I've learned on this forum; So far I've been able to adjust the speed limiter, but I need help with adjusting the Torque Management, if any one of you more experienced tuners here wouldn't mind giving me some pointers on TM adjustments I would really appreciate it, please PM me, or post a link that applies to this vehicle,or post a snapshop of the editor screen that deals with TM reduction? that would be great.
Thanks & regards
Hi Tom!! Nice to see you over here! I mostly read & lurk. There is a whole lot of info over here, so much that it gets overwhelming at times. But don't give up, you'll catch on.
For me, it all started with a crappy mail-order tune. Followed by another crappy one, and so on. Until I couldn't stand it anymore. I decided to get HPT and figure things out for myself. Best purchase I've made so far, by far. Once I started really learning how to use the software, I found out that my "tuned" pcm had a stock VE table. Does that sound right for a cammed/supercharged 5.3?? How did it even run?? With a raped PE table, that's how. Send me a pm if you want any more details than that.
Anyways, I'm currently working on my 2-bar OLSD tune. So far, things have been fairly straightforward. My VE table below 105kpa is nearly spot-on, and I just need to get the rest finished up. Truck mods listed below.
2001 ECSB 4x4, 5.3, Radix, 3.0 pulley, VHP Trucker cam, 1.8 Crane roller rockers, 4L65E, Yank SC3000, 3.73, Cal-Tracs, HPTuners 2-bar OLSD.
hey all i am proud to be tunning my 05 yukon denali with a garret T4OE .60AR under mount turbo, 39mm turbo smart waste gate with controler, 14X36X4 JDM air to air intercooler, turbo smart 50mm BOV, walbro 255 lph fuel pump and bucket convertion, Fast 65# fuel injectors, snow meth kit maf based, 4l80ehd and a lot of blood swet and tears.
2005 yukon Denali turbo,@15#s 4L80E,1978 z28 lq4,1974 corvette ls6. there is no measurment of power without load.
97 K2500 Vortec 454/4L80E, 0411 pcm swap. I just finished up the swap this past weekend. I plan on getting a decent cam in the truck soon to help out when I am towing the trailer.
1997 Chevrolet K2500 ECSB L29/4L80, Mid-length Headers, Cat-delete, Custom Catback, Airlift Airbags, 0411 PCM Swap.
2004 Pontiac GTO M6 Ported Dart 225s, SI5 cam, Ported FAST 90, SLP LTs, Bassani catback, Pedders Track Coilover, GMM Ripshift, Spec 3. Numbers to come...
Hey Everybody, trying to do my own, anybody, from Louisiana, I'm in Golden Meadow, It's on the way to Grand Isle.
'99 Silverado ECSB w/5.3, Patriot Performance Heads (2.02in 1.57ex) milled .050, LSXrt intake w/FAST 102mm TB, Comp/EPS Cam (226/230* dur .598/.600" lift 113 +2 LSA), 44# injectors, LS7 Lifters, Stock Rockerarms, Double Roller Timing Chain, ARP Head & Rod Bolts, HV Oil Pump, Vigilante 9" Converter 3600 stall, FLT Level 5 4L65E, K&N 77 series, Pacesetter LT, No Cats, Magnaflow Mufflers, True Duals, TB Bypass, Truetrac, 4.10's, E-Fans, HP Tuner
'10 Camaro 2SS/RS RJT, L99, A6: Stock
