OK guys, here's the deal. I've been doing some WB testing with my car and have found that I would like to go a little deeper in PE in the higher sections of my MAF.
Our VCM does have a PE referenced by time modifier. Positive #'s in that table will lean and so on.... My question is, when scanning, if I were to use that modifier to go deeper in PE from 5600rpm to 6400rpm(-.2), will it show in my scan as the lower PE commanded? Meaning, for example, when I hit 5600rpm will HP show the 12.9 that is commanded from the coolant referenced table and just add to that, or will it switch to the 12.7 that I want for the top end?
I am thinking that if I put -.2 in that time table for all time values in the 5600 and 6400 RPM columns, that when I hit 5600 RPM that the scanner will show that I am commanding 12.7 and not 12.9.
I'm game for experimenting with the program, but PE is not the place for experiments if you ask me...
