I recently upgraded my turbo and found I also needed to adjust/increase my VE table values in the upper kpa cells. Well! In reviewing my tune I come across the MAP Sensor calibration and started to question the values.
I have been tuning a 2 bar OS for a while and using a GM#12580698 map sensor which I set the linear setting to 200 & offset value to 10.33 in the calibration settings. Don’t remember where I got these numbers.
So back to the search feature I go!!!
After substantial hunting and reading I found reports that the offset value should have been (8).
Today I changed the offset value to (8) and found my WB02 reflecting leaner A/F ratios at corresponding kpa values . I run up to approx. 150-160-kpa only. I did not push it further to the 206-208 kpa normal boost level.
Can someone please explain what function the offset table performs and how it affects the tune?
Further, can someone please verify the linear and offset values for the GM#12580698 sensor?
Will I be doing my tune an injustice by leaving the previous value as long as I acquire the proper A/F ratio and the WB02 and Commanded agree?
