Ill be attaching copies of my DAL, Max Air and TQvsRPM tables but here's the issue:
Everything is set so I should be getting 22psi and tapering to 19-20 at redline. Im not getting the full 22, Im getting about 21. It will spike and plateau for a second, then dip down slightly for a second and then pick back up and level off. The load % goes down as well as the MAF Lbs/Min.
Should I try backing down the DAL's a bit until I see a change? Am I trying for too much there?
Im also all stock, only mod is a drop-in filter. Is it possible the BPV spring isn't holding at that load?? (reaching, i know lol)
I've included a log of a 3rd and 4th gear WOT pull on the highway. You will see what Im talking about, the pull starts 450-500 timestamp.
Thanks for looking!
