Sorry if this happens to be in the wrong spot, but it looks like the lk9 used in the turbo saab's in the application that I'm looking at isn't supported by hpt?
Any reason why or am I wrong? Thanks.
Correct they use an unsupported PCM.
Any possibility of support at all?
Just wondering because the only other "low cost" option is a canned BSR tune and meh. Ha.
Not anytime in the foreseeable future.
The Saab 9-3, at least the 4-cylinder models, use a Trionic 8 computer, whatever that means.
Trust me, I'm itching to turn up the boost a little bit, nothing crazy, just from the factory 12psi to 14-15psi. I've read where some guys are seeing as much as 19psi of boost.
2000 T/A - Thompson Motorsports 416ls3, F1A procharger, HP tuned. Just a couple psi of boost.
2013 Mercedes C350, wish HPtuners worked.
