Will mounting a WB O2 in the post catalytic bungs affect afr readings? I would like to take a quick look at a friends truck without drilling and welding another bung in. Thanks ahead of time for any input.
I have found that, the bung in front of the CAT will produce most accurate readings. While using post CAT bung readings will be erratic during idle or light throttle.
06 LQ4 2500HD CC LB 4wd 4.56, Dana 60,
17 3500HD 6.0 srw
GenIII Unlimited GM Full Size Truck/SUV
Serial cable to WiFi
Yes. Almost .25 to .50 difference. If you choose to use the bung before the CAT you will have to tune in OL (Open Loop) only.
Janky Monkey Tuning
Call or PM for tuning solutions.
Cell 210-954-4985
Wrench turning provided by 2 Tightwads Racing.
Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
Still lost? Consult a Pro!
www.thetuningschool.com
www.calibratedsuccess.com
www.tunedbyfrost.com
So my best bet would be use on of the pre cat locations and tune in open loop? This shouldn't be to big of a deal if I tune the VE before and then switch to OL to do WOT tuning?
