Sorry if this is a long post, but I am posting everything we know about this car
So I am helping my friend swap an LS1/4L60E into his mustang. The wiring harness was custom built by a company and is very similar to a Painless. The PCM came out of a 2001 S10/4.3, with the numbers that matched exactly what the wiring harness company said to get (The OS Number is 12208322, don't remember what the PCM P/N was).
After installing the PCM, I copied ALL settings from a stock 2001 Camaro (5.7/Auto) over to the old S10 PCM and it seemed to take all the settings.
So it is all hooked up, and when we crank the motor, all 8 injectors fire like they should, but only cylinder 1 is getting spark, but it is getting LOTS of spark, as far as I can tell it, all 8 sparks are firing through the first coilpack.
I have checked the CKP while it is cranking and it seems to be reading 0-7, so it is working, as far as I can tell.
Anyone have any ideas? I have attached the HPT that I am trying to crank the car with.
Here are my theories:
1) Bad PCM, it was bought of ebay for like $25. It seems to be in decent shape, HPTuners had no problems reading/writing/scanning.
2) Something is incorrectly set up in the HPT or OS of the PCM. It is acting like there is a single coil with a distributor, but I can't find any sort of setting that will allow you to set up a Coil On/Near Plug DIS setup or a traditional electronic distributor.
