Results 1 to 7 of 7
Thread: 63# injctors
    63# injctors
    Do any one tuned ford 3V with 63# injctors ? ( I need Calibration Summary)
    Saoud bin ajail
    Dubai p.o.box :24687
    United Arab Emirates
    Moblie:+971507744161
    WhatsApp:+971509345593
    [email protected]
    Quote Originally Posted by eficalibrator View Post
    Ford has all of the injector summary sheets on the FRPP website:
    http://www.fordracingparts.com/parts...tKeyField=9988
    The various injector summary reports are at the bottom of the page.
    I use the same summary her but same ,i use to work with 63lb/hr Siemens . i have my own tune it work fine with this injectors but too rich .
    Saoud bin ajail
    [email protected]
    Tuner lito's Avatar
    Aug 2008
    Caracas, Venezuela
    71
    Usually 63# are measured at 3 bar, so they are actually normal 60's @ usual Ford's 39psi.
    Quote Originally Posted by lito View Post
    I KNow that mate but whaat are happan is lumda fule read lean & rich in same RPM .in the low rpm read too rich .what i knoe in gm if you sive for the 60s in work fine .
    Saoud bin ajail
    [email protected]
    Oct 2007
    Crawfordville, FL
    2,456
    You don't control fuel by RPM, but by Mass of Air.
    Eric Brooks
    HP Tuners, LLC
    Jun 2005
    Southern FL
    2,044
    As Greg linked you to, here is Ford Racing's (different department than "Ford") values for those injectors:
    http://www.fordracingparts.com/parts...-9593-lu60.pdf
    Also, just so you'll know for sure, as lito mentioned, the 63.5# injector you state is actually a 60# at 39.x psi (what Ford uses for fuel pressure), so Ford's part #M-9593-LU60 is the same injector, provided yours is the Siemens Deka (it'll be carved into the injector).
    Now look at the Ford Racing values for the "ALOSL" ("Flow Rate Low" in HPT) and "AHISL" ("Flow Rate High" in HPT). Ford has them listed in lb/s. HPT has them listed in #/hr. So all you need to do there is take Ford's value and multiply it by 3600 to convert seconds to hours. i.e. 0.016741 * 3600 = 60.2676, and 0.017552 * 3600 = 63.1872.
    Another thing, Ford Racing's "Pulsewidth" value for the 60s is listed as "MINPW (ms) 1.391" (expressed in milliseconds). That's a bit high, and you'll probably never get the fuel trims at idle correct with using that value (the injectors won't pulse properly). I know this because many of us "in the know" tuners have tested them against other "proper" data supplied to us from internal and external Ford engineers and calibrators. So, I'd suggest to set it to 0.94986, and try that.
    Furthermore, on the "Injector Offset vs. Voltage" function in HPT, you're gonna fock yourself if you copy Ford Racing's "FNPW_OFFSET" values direct from the pdf file. Why? Ford Racing shows the values for the parameter in EEC-V specs. The EEC-V pcms has these parameters listed in seconds, and the the newer Oak pcms have them in milliseconds. Therefore, you just take the values for the EEC-V pcm and divide them by 1000. Here's Ford Racing's values in the proper format for HPT:
    Code:
    	PW Offset
    0.00	0.0025900
    0.00	0.0025900
    0.00	0.0025900
    6.00	0.0025900
    8.00	0.0014410
    10.00	0.0009210
    11.00	0.0007580
    12.00	0.0006360
    13.00	0.0005180
    14.00	0.0004090
    15.00	0.0003120
    15.90	0.0003120
    Notice the voltage difference on the left hand column? Open up the Injector Offset parameter and then click on "Volts (V)" on the left, and then replace the values with this:
    Code:
    	V
    0	0.000
    1	0.000
    2	0.000
    3	6.000
    4	8.000
    5	10.000
    6	11.000
    7	12.000
    8	13.000
    9	14.000
    10	15.000
    11	15.900
    Don't forget to copy in the other values Ford Racing lists:
    FUEL_BKPT (lb) - "Breakpoint" in HPT
    FNPW_BKCOMP - HPT hasn't given us this parameter yet, unfortunately (SCT has, tho ).
    FNPW_LSCOMP - "Flow Rate Low Mult vs. Pressure" in HPT
    FNPW_HSCOMP - "Flow Rate High Mult vs. Pressure" in HPT
    FNPW_OFFCOMP - "Offset vs. Pressure" in HPT
    These last four are important for when fuel pressure changes on the EFRS (Electronic Returnless Fuel System) vehicles.
    Once you input ALL of these parameters properly, then you need to do as Eric said above, and dial in the MAF transfer. That is VERY important. Without telling the pcm how much airmass is entering the engine, you'll never have your fueling correct.
    Formerly known as RWTD
    Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
