What would I need to adjust to correct the idle from going up to 1500rpm at low speed before coming to a stop. Once the car stops the idle returns to normal. I was able to get the car to idle fine at startup. I stuck to the instructions on idle in the stickies and I drilled the TB blade. The car is a m6 with ms4 cam. thanks
