Will the Dodge release that is coming soon support the V8 Magnum engines?
2000 Regal GS | Twin-Charged T72 | HPT Pro + PLX Wideband | 12.55 @ 110 on 15psi | Now running 20psi on E85!
1998 5.9L Durango | Powerdyne supercharger @6psi | Mesa Headers | Gibson Cat-back | 1.7 RR's | Tuned PCM | Ported Heads | Custom TB & Intake | Custom fuel rails | Rebuild coming soon...
His Durango uses a JTEC PCM not a NGC3. But it seems that JTEC will be supported too. I hope it at least.
'97 Jeep Grand Cherokee ZJ, 5.2L (Canada Import), 2" Lift
(CAI, Modded Kegger, Ported TB, 3" Cat-Back, SCT Custom Tune)
'98 Jeep Grand Cherokee Limited ZG, 5.9 V8, Stock
'03 Skoda Fabia, 1.4L 16v
'98 Chevrolet Camaro V6, 3.8L, Targa, ZZP GT1 Cam, Dynomax Cat-Back [sold]
I should have read closer, I assumed the Magnum = the LX wagon not the Magnum engine.
My bad.
Keith has a Viper so yes the JTEC will be supported soon after...
I count sheep in hex...
NGC3 will be first, then JTEC.
Do you have any kind of rough time frame?
A month, 2 months, 6 months??
Can you tell me if the NSRT4 will be supported up front as well? I believe it has the NGC3 as well.
I understand.
I'm just glad to not be in the dark so much!
Thanks for the update.
I think (hope) this means that Keith and the crew have a good reason to come up with a proper way to run boost with the JTEC
- Chris
www.dcperformance.com
if you can convince Keith to put FI on it then yeah, maybe... BIG maybe.
Rofl
Back on topic ....
This stuff will be out next week?
