Results 1 to 17 of 17
Thread: tire pressure sensor thresholds (for lifted trucks)
    Feb 2006
    41
    i have a 2007 2500hd lmm with big tires
    beacuse of this my tire pressure is lower than my flat tire warning thresholds
    **it would be great if i could get into that table and change my thresholds for when the car starts warning me of a flat tire**
    as of now mine is set at a min pressure of 60psi while the max psi of my tires is 55psi .... without this feature im kinda fucked!
    28,305
    Sounds like a non pcm/tcm related module ie abs or something else is probably causing the issue.
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    IIRC it's the RFA module (radio frequency actuator). Runs the Key Fobs too.
    Always Support Our Troops!
    Feb 2006
    41
    So How Do You Adjust That?
    Feb 2006
    41
    I Know It Triggers A Dash Light So Wouldent That Have O Be Throu The Pcm?
    Apr 2003
    Almost 2000 feet.
    7,876
    You can't adjust it. Factory programmed when the module is installed.
    Feb 2006
    41
    so im just fucked?
    Feb 2006
    41
    is there a way i can trick it? with hardware?
    Apr 2003
    Almost 2000 feet.
    7,876
    Not unless you are going to modify the tire pressure sensors themselves or the on board module.
    Oct 2006
    N-B ,Canada
    57
    Some are saying,take the sensors and install all 4 in the spare tire,but we tried it today,and it did not work.I understood that it works on the Fords but not on Chevy's.I know you can lower them by using a Snap On or OTC tool,or ask the dealer to lower it(if your really nice to them).
    I would like to modifie this setup also,for Bigger tires,winter tires etc.....
    Feb 2006
    41
    The Dealer Said They Cant Do It
    Im Not Sure If They Know What They Were Talking About Or Not ..
    Is There An Adjustment For These Or Can I Atleast Kill A Dtc In The Tune That Will Just Shut The Dam System Off?
    Tuner driftnpow's Avatar
    Feb 2008
    South West WA
    151
    maybe enquire the head office via phone to a techy or shoot them an email to see if it is possible and to whom may be able to adjust it for ya? no harm im trying eh!
    Dec 2007
    17
    That dealer lied to you, or at least wasn't aware of some facts.
    My whole job at the dealership is building lifted trucks. If you try and pump a 35"tire up to 60 psi, or 72 in the rear as the factory wants they ride and wear like crap.
    Go back to the dealer, tell them to get a tech 2 with a candi module and go into the RCDLR module. Under the module setup you can chose what load rating and tire pressure you'd like for the vehicle. I typically set them up for around 37 psi and run the tires at 40. You may have to do a tire sensor relearn after the setup procedure is done.
    Now keep in mind that the reason that GM wants the tire pressures so high is to meet the load rating of the truck. If you intend to carry weight upp to the max capacity then you should adjust your pressures accordingly.
    Tony
    Dec 2007
    Horicon, WI
    35
    Founds this over on gm-truck.com...
    You can use the same sensors, but you will need to reset the computer for a new nominal pressure. The range is nominal +/- 10 PSI. My dealer did this for me for $65. This program is stored in the RDL (Remote Door Lock) Module. It requires the use of the latest Tech II scan tool.
    Same thread contained this from a GM tech that posts there...
    Tire Pressure Monitor Description and Operation
    The tire pressure monitor (TPM) system warns the driver when a significant loss, or gain of tire pressure occurs in any of the 4 tires and allows the driver to display the individual tire pressures and their locations on the driver information center (DIC).
    The system uses the body control module (BCM), driver information center (DIC), instrument panel cluster (IPC), remote control door lock receiver (RCDLR), a radio frequency (RF) transmitting pressure sensor in each wheel/tire assembly, and the serial data circuit to perform the system functions. Each sensor has an internal power supply with a 10 year service life.
    When the vehicle is stationary, the sensors internal accelerometer is inactive, which puts the sensors into a stationary state. In this state the sensors sample tire pressure once every 30 seconds and do not transmit at all if the tire pressure does not change. As vehicle speed increases, centrifugal force activates the sensors internal accelerometer causing the sensors to go into rolling mode. In this mode, the sensors sample tire pressure once every 30 seconds and transmit in rolling mode once every 60 seconds. The RCDLR receives and translates the data contained in each sensors RF transmission into sensor presence, sensor mode, and tire pressure. The RCDLR sends the tire pressure and tire location data to the DIC via the serial data circuit where they are displayed.
    The sensors continuously compare their last pressure sample to their current pressure sample and will transmit in re-measure mode if a 8.3 kPa (1.2 psi) change in tire pressure has been detected in either a stationary or rolling state. When the TPM system detects a significant loss, or gain of tire pressure, the tire pressure monitor indicator icon is illuminated on the IPC and if equipped, a check tire pressure type message is displayed on the DIC. Both the indicator icon and DIC message can be cleared by adjusting the tire pressures to the recommended kPa/psi and driving the vehicle above 40 km/h (25 mph) for at least 2 minutes.
    If power is disconnected from the RCDLR or if the vehicle battery is disconnected each TPM sensor ID is retained but all of the tire pressure information is lost. Under these circumstances the RCDLR cannot assume that the tire pressures were maintained over an unknown period of time. If equipped, the DIC will display all dashes and the scan tool will indicate a default tire pressure value of 1020 kPa (148 psi) for each tire. Driving the vehicle above 40 km/h (25 mph) for at least 2 minutes will activate the sensors causing the DIC to display the current tire pressures. The J-46079 TPM special tool or the pressure increase/decrease method may also be used to activate the sensors as well.
    The RCDLR has the ability to detect malfunctions within the TPM system. In the event a DTC is set, the tire pressure monitor indicator icon on the IPC will flash for 1 minute and then remain illuminated after the ignition is turned ON and the IPC bulb check has been completed. Any malfunction detected will cause the DIC to display a service tire monitor system type message. For more information on other functions of the RCDLR, refer to Keyless Entry System Description and Operation .
    Scott Braemer
    2000 NHRA Trans Am - LS1
    2006 Trailblazer SS - LS2
    2008 GMC Sierra Denali - L92
    Dec 2007
    Horicon, WI
    35
    Continued...
    Customer Concerns and Confusion
    When a customer comments on a condition related to tire pressure monitoring, it is very important to distinguish between Check Tire Pressure / Low Tire Pressure conditions and Service Tire Monitor system issues. Understanding the difference between the two distinct conditions will help you distinguish between normal system operation (tire needs air) and a system malfunction.
    There are two important differences between a Check Tire Pressure / Low Tire Pressure message/light and a Service Tire Monitor message light:
    • A Check Tire Pressure / Low Tire Pressure message/light will stay on solid and no system codes are set. The TPM system is operating as designed. Correcting the tire pressure will resolve the issue.
    • A Service Tire Monitor message/light will blink and system codes WILL set. There is a condition that should be diagnosed and corrected.
    Tire Pressure Light:
    Service Tire Monitor System (light blinks, then stays on)
    The Tire Pressure Light will blink for about one minute and a Service Tire Monitor message will be displayed when a system malfunction occurs. For example: If one or more tire pressure sensors does not transmit information for 18 minutes of driving, the TPM system WILL set a code, display a message, and BLINK the light for about a minute, after which the light will stay on solid for the remainder of the ignition cycle. If the system fault is intermittent, the message/light may also be intermittent - on during some ignition cycles, off during others.
    Low Tire Pressure Warning (light stays on solid)
    If the TPM system detects a tire pressure below the threshold, the Check Tire Pressure message and the Tire Pressure Light will come on and stay on. The message and light may be intermittent in nature, especially during cold weather.
    Conditions That Will Cause the Low Tire Pressure Warning Message/Light to Display:
    • The tire may have picked up a road hazard and/or have a slow leak.
    • The tire pressure may not have been checked in the past six months.
    • The air pressure in a cold tire may be at the pressure where the system is required to warn the driver. However, that same tire will rise in temperature and pressure as the customer drives, causing the message and light to go out.
    • The tires may have been rotated, pressures adjusted, and the new tire positions were NOT re-learned into the vehicle. This can occur on vehicles that have two different placard pressures for front and rear tires.
    • There may be a slow leak in one of the wheel and tire assemblies (Valve Stem, Wheel Rim, or Aluminum Wheel Porosity Leak). If this condition is found, please refer to bulletin:
    • #05-03-10-003B - Low Tire Pressure, Leaking Cast Aluminum Wheels (Repair with Adhesive Sealant)
    • #04-03-10-001C - Info - Tire Puncture Repair Procedures for all Cars and Light Duty Trucks
    The Effect of Outside Temperatures on Tire Pressures
    Important: As a rule of thumb, tire pressure will change about 7 kPa (1 psi) for every 6°C (10°F) decrease in temperature - dropping when it gets colder outside, rising when it gets warmer.
    Tire pressure should be set to the specified placard pressure at the lowest seasonal temperature the vehicle will encounter during operation.
    The correct action to avoid a Check Tire Pressure message due to extreme temperature changes is to do the following:
    • Use an accurate, high quality tire pressure gauge.
    • Re-learn the TPM sensors and adjust the tire pressure to the placard values after every tire rotation.
    • Let the vehicle sit and adjust the tire pressure to the specified value when the tire temperature is at the lowest expected temperature.
    • Never set the tire pressure below the placard value regardless of tire temperature or ambient temperature.
    Important: On extremely cold days, if setting the tire pressure when the vehicle has been indoors, it may be necessary to compensate for the low outside temperature by adding 21-27 kPa (3-4 psi) more than the placard pressure. At some later time, when convenient and when the tires are cold (outdoors), the pressure should be re-checked and adjusted to the placard pressures if necessary.
    Scott Braemer
    Dec 2007
    Horicon, WI
    35
    Continued...
    TPM Frequently Asked Questions (FAQ's)
    The following are some of the most asked questions:
    Q: What is a Tire Pressure Monitoring System?
    A: The TPM system consists of four sensors (one in each wheel), which transmit wireless (RF) signals to a vehicle receiver (typically, the same receiver that performs the keyless entry function), the Low Tire telltale, and the Driver Information Center (if equipped).
    Q: Do all Vehicles Have Tire Pressure Monitoring?
    A: Starting with the 2008 MY, all GM vehicles sold in the United States are equipped with tire pressure monitoring, to meet the mandates of FMVSS 138. Some vehicles built prior to the 2008 model year or sold in Canada have tire pressure monitoring; check vehicle build and RPO information to be sure.
    Q: What does the Low Tire Telltale Look Like?
    A: The Low Tire telltale is a yellow telltale that looks like an exclamation point inside of a horseshoe:
    Q: When does the Low Tire Telltale Come On?
    A: The Low Tire telltale MUST come on when a tire's pressure drops to 75% of the Recommended Cold Inflation pressure (the pressure value printed on the vehicle placard - the yellow and white sticker in the driver door opening.)
    There are several events that may cause a Low Tire warning:
    • On vehicles where a different placard pressure is required between the front and the rear axles, the tires may have been rotated, pressures adjusted, and the new tire positions were NOT re-learned into the vehicle.
    Q: What does the TPMS Malfunction Warning Look Like?
    A: The TPMS Malfunction indicator uses the same telltale as the Low Tire warning. The telltale will flash for the first 60 seconds of a KEY ON event, and then go on solid.
    Q: How can I tell the difference between a Low Tire and a system malfunction?
    A:
    • A Low Tire telltale will be on solid immediately after KEY ON, and will be accompanied by a CHECK TIRE PRESSURE message in the Driver Information Center (if equipped).
    • A system malfunction causes the telltale to flash for the first 60 seconds of a KEY ON event, and then go solid.
    Tip
    These behaviors repeat at each KEY ON cycle. The best way to diagnose the vehicle (if you're not sure which warning is being displayed) is to KEY OFF and KEY ON again while watching the telltale and DIC messages.
    Q: When are Diagnostic Trouble Codes Reported?
    A: DTC's are reported ONLY when there is a system malfunction (flashing telltale). When a Low Tire (solid telltale) is displayed, that means that the system is working exactly as it's designed to do - since there's no malfunction, there is no need for a DTC.
    Q: What service is needed if the Low Tire telltale is on?
    A: When a vehicle comes in with a Low Tire warning, the tires should be checked for any leaks or damage (from road hazards). After those have been repaired (or if none are found), the tires should be inflated to the pressure shown on the Vehicle Placard - the yellow and white sticker in the driver door opening. It is not necessary to relearn the sensors after correcting the pressure.
    Q: Can Tire Pressure Monitoring be turned off?
    A: Tire Pressure Monitoring is now a mandated safety system in the United States and cannot knowingly be disabled by an OEM nor an aftermarket service provider (49 USC 30101).
    Q: Can the Tire Type and/or Placard Value be changed, if aftermarket tires or wheels are installed?
    A: The Tire Type (P Metric, LT Load Range C/D/E) and the Placard Value (Front Placard and Rear Placard, individually) are stored in the receiver as calibrations and CAN be revised at a GM Dealership with a Tech 2. (The RCDLR Setup screens allow this.) Since the under-inflation threshold is calculated as a percentage of the placard; correcting the placard values when different tires are installed will bring the vehicle back into compliance.
    Q: What is Sensor Learning (Sensor Re-Learning, Sensor Training, Sensor Matching)?
    A: Each sensor has its own unique identification code (ID) that is transmitted as part of its wireless signal. The receiver stores and uses these IDs to determine which sensors are installed on the vehicle, and in which corner of the vehicle the sensor resides in (so that both the pressure information provided in the Driver Information Center and the diagnostics are correct). Sensor Learning is the process that puts sensor ID information into the receiver.
    Q: When is Sensor Learning required?
    A: Sensor Learning should be done when the vehicle's tires are rotated (since sensor position on the vehicle has changed) or when a sensor is replaced/a new sensor is installed (since a new ID has been introduced to the vehicle). Sensor Learning is not required when simply correcting the tire pressure resolves the vehicle problem.
    Q: Why are dashes (" - - "), or a pressure value of 148 PSI (1020 kPa), sometimes displayed after a battery disconnect?
    A: These displays come up after a battery disconnect/reconnect because the system is waiting for updated pressure information to be sent from the tire pressure sensors. As each sensor transmits its information, the display is updated appropriately. Note that when dashes or 148 PSI (1020 kPa) are displayed after a battery disconnect/reconnect, the System Malfunction warning is NOT displayed - because the system is still working properly, and simply waiting for updated information from the sensors. Driving the vehicle above 20 mph (32 km/h) for 2 minutes gets the sensors talking, and restores the correct pressure values to the display. It is also possible to restore the values by using the J-46079 TPM tool, using the "Activate" function at each tire to activate the sensor (it is NOT necessary to put the system into Learn mode, in this special case).
    Q: Is there a sensor installed in the spare tire?
    A: No - a sensor is not installed in the spare tire.
    Q: Are all of the sensors the same?
    A: All of the sensors are not the same. They are supplied by different manufacturers, and send different RF signals to the vehicle. SOME of the sensors are interchangeable, though - while they may look different, they DO send the same RF signal to the vehicle and MAY be used in place of one another on a vehicle. See the Sensor Information Guide for more details about which parts are interchangeable.
    Q: What size is the sensor nut?
    A: The sensor uses an 11 mm hex nut for attachment.
    Q: Will a tire pressure sensor fit in every wheel?
    A: GM wheels (including Accessory Wheels available from GM SPO) are designed to accommodate tire pressure sensors. Many aftermarket wheels also accommodate tire pressure sensors, but not all do. In some, the valve stem hole is placed in such a way (pointing straight into the middle of the wheel, for example) that the motion detection components inside the sensor will not work correctly.
    Scott Braemer
    Dec 2007
    Horicon, WI
    35
    Continued - final...
    Q: Can the valve core be replaced?
    A: The valve core can and should be replaced if it is removed from the sensor, but the replacement part depends on the material of the valve stem (Refer to Service Bulletin # 08-03-10-005).. Sensors with a rubber valve stem may use a standard brass valve core for replacement. Sensors with an aluminum valve stem CANNOT use a brass core; instead, they require a nickel-plated valve core to protect against the corrosion that forms when dissimilar metals come in contact. See the service parts guide for the correct GM part numbers to order and use.
    Q: Can the grommet (and washer) be replaced?
    A: The grommet (and washer) can and should be replaced if the sensor is removed from the wheel. The rubber grommet provides the air seal in the valve stem opening, and a new one should be used to ensure a fresh seal after each service. See the service parts guide for the correct GM part numbers to order and use.
    Q: Can the rubber valve stem be replaced by itself?
    A: The rubber valve stem is attached to the sensor electronics by a TORX screw. The valve can and should be replaced whenever the sensor is removed from the wheel. See the service parts guide for the correct GM part numbers to use.
    Q: Can the sensor be cleaned with a sharp pin?
    A: NEVER use a sharp object to clean the pressure port of the sensor; it can be damaged and lead to part failure. If the dirt/grime/obstruction cannot be removed with a cloth, replace the sensor.
    Q: How long will the sensor's battery work?
    A: The sensor is designed to last for 10 years or 150,000 miles (240,000 kilometers).
    Q: Are tire pressure sensors compatible with aftermarket tire sealants?
    A: Tire pressure sensors are not compatible with commercially-available tire sealants. Tire sealant materials can clog the pressure port of the sensor, and lead to inaccurate pressure readings and improper Low Tire warnings. Additionally, some sealant products use materials that can degrade the protective potting material that covers the sensor's electronics.
    Q: Are tire pressure sensors compatible with GM Inflator Kits?
    A: While tire pressure sensors are NOT compatible with commercially-available sealants, they HAVE been tested and ARE compatible with GM Inflator Kits and the sealant that they use. After inflator kit use, the sensor should be inspected for any damage, and replaced/cleaned as needed.
    Q: Are tire pressure sensors compatible with nitrogen inflation?
    A: Tire pressure sensors are compatible with nitrogen inflation (normal air is already 78% nitrogen).
    Q: How do changing outside temperatures affect tire pressure?
    A: All gases change pressure as their temperature changes, and air or nitrogen are no exceptions. A good rule of thumb is that tire pressure will change by about 1 psi (7 kPa) when temperature changes by 10° F (6°C). Customers may experience this as temperatures change from summer to fall and into winter - tire pressures will drop as the outside temperature gets colder. Customers may also experience this as temperatures change between mid-day and overnight.
    Q: How should tire pressures be set at PDI?
    A: Tire pressure should be set to the specified placard pressure at the lowest seasonal temperature the vehicle will see during operation. The correct action to avoid a CHECK TIRE PRESSURE message due to extreme temperature changes is to: Use an accurate high quality tire pressure gauge. Let the vehicle sit and adjust tire pressure to the specified value when tire temperature is at the lowest expected temperature. Never set tire pressure below the placard value regardless of tire temperature or ambient temperature On extremely cold days, if setting tire pressure when the vehicle has been indoors, it may be necessary to compensate for the low external temperature by adding 3-4 psi (21-27 kPa) more than the placard pressure. When convenient, at some later time, when the tires are cold (outdoors), the pressure should be re-checked and adjusted to placard if necessary.
    Q: When will the J-46079 tool be updated?
    A: TPM Software Version 3.5 has recently been shipped to each GM dealership in the J 46079-30 TPM update kit. This update consists of two parts:
    • A hardware update kit which consists of a custom rechargeable battery pack, battery cover with charging terminals, and a charging cradle with a smart charger where the whole tool will fit into the cradle for charging (same concept as a cordless phone). This hardware update substantially increases the life of the batteries and will assure that the TPM Tester always has full battery capacity.
    • The software update will add new vehicles and also improve the speed of the tool’s read-back ability and accuracy. Sensor transmission signal strength is displayed in the upper left corner of the main display next to the tool’s battery level display. When the tool is used in both activate or scan mode, it will receive the sensor’s transmission and indicate its signal strength. It is important to note the sensor’s transmission signal strength since it is a good indication of an accurate diagnostic.
    Q: Where should the J-46079 tool be positioned when it is being used?
    A: Tool User Tip: The placement of the TPM Tester’s antenna when activating a sensor is critical, especially with the latest software update. When activating a sensor, the antenna tip of the TPM Test J 46079 must be placed on the sidewall, perpendicular to the tire, and close to the valve stem. This will assure proper activation of the sensor. If the antenna of the TPM Tester is placed either on the valve stem or on the wheel itself, the tool may not properly activate the sensor, causing improper diagnosis.
    Warranty Information
    GM is very concerned about customer safety and tire performance. Anytime a customer brings a GM vehicle in for a tire or tire pressure monitoring concern, we encourage our dealers to perform a complete check of tire conditions, pressures, and the TPM system if necessary. Under normal circumstances, the condition of tires, TPM reprogramming during tire rotation, road hazard repairs, and checking/maintaining tire pressure are the responsibility of the vehicle owner. GM Dealers should encourage customers to inspect/check and maintain their tires and tire pressure on a regular monthly basis.
    The tires and the tire pressure monitoring system are covered by the vehicle bumper to bumper warranty for manufacturing defects. It is GM's responsibility to perform repairs when a defect exists. If no defect exists, the customer should be responsible for the tire/system check.
    GM does not cover the normal inspection and maintenance of tires and tire pressure. The use of this labor operation E0716 is intended to identify system defects and verify proper operation.
    Scott Braemer
