Results 1 to 6 of 6
Thread: error
    Tuner checkmate's Avatar
    Oct 2004
    Front Royal, VA
    81
    error
    Tried to scan/tune a friends car that I have had no issues with before.
    Scanned fine, then went to update the tune.
    By clicking the write cal button in the vcm editor
    this is the tune::
    this file
    And then I would get this error:
    error
    Full error:
    Heres the debug wording:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.ComponentModel.Win32Exception: Error creating window handle.
    at System.Windows.Forms.Control.SetVisibleCore(Boolea n value)
    at System.Windows.Forms.Control.set_Visible(Boolean value)
    at u.?()
    at u.?(Object A_0, EventArgs A_1)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
    at System.Windows.Forms.ContainerControl.WndProc(Mess age& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
    at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    Assembly Version: 2.1.16.0
    Win32 Version: 2.1.16.0
    CodeBase: file:///C:/PROGRAM%20FILES/HP%20TUNERS/VCM%20SUITE%202/VCM%20EDITOR.EXE
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    C1.Win.C1FlexGrid
    Assembly Version: 2.5.20053.220
    Win32 Version:
    CodeBase: file:///C:/PROGRAM%20FILES/HP%20TUNERS/VCM%20SUITE%202/C1.Win.C1FlexGrid.DLL
    C1.Common
    Assembly Version: 1.0.20031.116
    Win32 Version:
    CodeBase: file:///C:/PROGRAM%20FILES/HP%20TUNERS/VCM%20SUITE%202/C1.Common.DLL
    C1.Win.C1Chart3D
    Assembly Version: 1.0.20053.15236
    Win32 Version:
    CodeBase: file:///C:/PROGRAM%20FILES/HP%20TUNERS/VCM%20SUITE%202/C1.Win.C1Chart3D.DLL
    C1.Win.C1Chart
    Win32 Version:
    CodeBase: file:///C:/PROGRAM%20FILES/HP%20TUNERS/VCM%20SUITE%202/C1.Win.C1Chart.DLL
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
    Then with the scanner I would get invalid cable.
    Rebooted my computer, turned the car off and on and nothing
    VCM info button provided this info, just in case you need it:
    Operating System: Windows XP
    Microsoft .NET: 2.0.50727.42
    VCM Suite Product: VCM Editor 2.22.3043.745
    VCM Suite ID: 00000A7093
    Year/Models:
    GM Firebird/Camaro (V8) 2001
    GM Firebird/Camaro (V8) 2002
    HELP!!!!
    1982 GMC S15 5.3 4L80e
    1954 Corvette ls swap in progress
    28,309
    Does it give you the unhandled exception every time or is there a specific set of events that you must do to get the unhandled exception?
    Oct 2004
    Front Royal, VA
    81
    When I try to start the scanner and write/read cause the error
    Sep 2002
    Chicago, IL
    6,397
    Please install the latest version of VCM Suite.
    We got this guy Not Sure, ...
    Oct 2004
    Front Royal, VA
    81
    Quote Originally Posted by Keith@HPTuners
    According to my customer page 2.22 is the latest and my software version is: VCM Editor 2.22.3043.745
    Which you like me to redownload this file and reinstall?
    Aug 2005
    Midlothian, VA
    205
    Quote Originally Posted by checkmate
    It shows here you are using 2.1.16.0. Maybe try uninstalling it completely and installing it fresh. HTH!
    Mitchell
    '04 Supercharged MC SS
    MOD LIST
    Custom PCM, Ram Air Hood w/ Air box, Intense MPS w/3.6", R/T DP with Ubend delete & HF CAT, LC-1 WB, GMPP Cat Back, Jacobs wires, 180 T-stat, & an Optima Red Top
