Can someone that knows more than me (which means all ok you ) take a look at this tune. I seem to be low on power, dyno'd at 390 for the components that I have and I also seem to be going through a lot more fuel than I think I should. I have a 2001 Vette LS1 with trick flow 215 heads (which were not milled and using stock gasket also have trick flow cam 228/230 .344 cam lift, .585 valve lift & 112 lope sep. A 25% underdrive pulley, LG street headers with catted x-pipe which connects to Z06 TI catback. Stll running the stock intake manifold and throttle body which are behind a vararam CAI. Oh yeah and a 3.42 rear end. Any suggestions would be great. I am running 10.5 compression and also run a 160 thermostat.
Frank
Oh yeah also the car pushes a little...example I can be doing 40 mph and take my foot off the gas and it never slows down. Mainly seems to do this from say around 50mph, don't notice it at highway speeds but it might be there not sure.
