Originally Posted by
RWTD
The code really doesn't matter, per se. You can swap most S197 tunes between on another, provided the Equizzer matches. If the Equizzer doesn't match, the vehicle will NOT start! One can easily change the Equizzer to match the code that's currently in the pcm. However, HPT doesn't give access to the Equizzer, unfortunately.
These following two tunes should interchange, due to the Equizzer matching:
07mustangwhippleSCTtune.hpt = Equizzer 396
Calibration ID: FPAF053
07mustangwhippleProCal.hpt = Equizzer 396
Calibration ID: FPASAG6
As for the two tunes, SCT doesn't have these in their database. It seems to me that it's an old file, which has been replaced by a newer Ford Racing tune. Or, either it's a new file altogether, and SCT hasn't yet put it in their database. However, it IS a Ford Racing calibration, so I can GUARANTEE you that the Equizzer values are different than the above two tunes. So you MUST use the ProCal to return the vehicle back to the factory tune before you start using a tune with a different Equizzer, otherwise the vehicle will NOT start!
07mustangwhippleHPtune.hpt
07mustangstocktune.hpt
Calibration ID: FPASAA2
So you will know, the 07mustangstocktune.hpt is NOT a stock factory Ford tune. With that being said, it does have the stock values for basically everything I lookd at. Off the top of my head, I would guess the real Ford factory tune is based off the FPAF053 calibration, which is a TNJ2 boxcode (look on the pcm of the car and see if you see a little white sticker with this on it). My guess is that when you used the Ford Racing ProCal tool to return the car back to stock, that it didn't return some of the calibration info back to stock, therefore HPT read this file out as a FPASAA2.
Also, your Voltage vs. Flow vs. Pressure table (FPVT = Fuel Pump Voltage Table) needs to be SERIOUSLY rescalled to reflect the voltages and ranges needed for that particular car, otherwise you're going to have continued fueling issues (erratic fuel pressure) once you go past 3.99 on the logged Flow Rate, especially once in heavy boost. If you've logged this table while tuning (there's approx. 5 to 6 parameters you need to log to do this), you'll notice you max out the flow rate after about 350 to 400 rwhp. This table must ALWAYS properly reflect the actual voltages and ranges for the vehicle, otherwise you'll be chasing your tail with your head.
A good start is to copy in the GT500 values (the voltage values, the flow rate values, and psi values), since the Whipple kits come with the GT500 dual fuel pump and dual FPDM arrangement. However, one issue with doing this with HPT is that you do not have the ability to increase the Inferred MAP limit (this needs to be increased so that the pcm recognizes when the car is in boost), nor the Flow Rate limit, like SCT gives you the ability to do, so you increasing the axis-ranges of this table, without increasing the range limits first, will do absolute jack. The GT500 already has these values increased straight from Ford, so it wouldn't be hard at all for HPT to implement the changes. That will probably never get done any time soon. Oh well...
FYI, ignorant Ford Racing doesn't even account for any of this. Also, whoever tuned it with SCT didn't even do this (any competent SCT tuner should always know better than this). I'd also shoot the SCT tuner for not even accounting for the undersized injectors (by increased the DeltaP at higher fuel flows, like what Ford Racing does in their tune), so those little 34# injectors are done by around 400 to 420 rwhp.
Okay, so what will get you out of this situation of no crank? Upload one of the tunes that will match the Equizzer value that's currently in the car. Of course, you don't know which one is which, so you will need to load one in until it does. If this doesn't work, a trip to the local Ford dealer, to have the factory file reflashed back into it, will rectify this. Then you MUST copy that factory file, then build off of THAT file for the Whipple setup.
