Results 1 to 16 of 16
Thread: Injector ratings
    28,303
    Injector ratings
    Alot of people are confused by the terms and the rating system so I'll try to explain a bit. A few people have come to me saying "I've got some 30lb injectors I wanna install how do I figure out what my IFR table should be" The first question I always ask is "What psi are the injectors rated at?" and undoubtedly the answer is always "I don't know" lol. So first things first Understand there is a ratings system when it comes to injectors where they are rated in bars or psi...1 bar=~14.5psi so when a company says "We've got 40lb injectors rated at 3 bar" that also means they are flowing 40lb/[email protected].
    Now here's where it gets tricky & most people don't know whats going on...LS1's generally have their fuel pressure at ~58psi not 43.5 MEANING those 40lbers@58psi are going to flow closer to 45lb injectors and can mean a HUGE difference in fueling characteristics. Most places that sell injectors will show you their ratings similar to this http://www.racetronix.com/17113739.html
    You all know about the excel IFR calculator thats already in the sticky so I wont go over that, but it'll basically do MOST of the work for you.
    Bottom line to this new sticky is to verify YOUR fuel pressure as well as the fuel pressure the injectors are rated at.
    Im leaving this thread open for discussion or corrections of any inaccuracies in the info I've given.
    Not A Tuner
    Oct 2006
    977
    Quote Originally Posted by foff667
    hahahahahahaah...how dumb can you be
    DH
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    very true
    Sulski Performance Tuning
    Nov 2002
    Central Florida
    2,503
    It's a pretty muddy situation because you have a
    variety of rating pressures, and your own pressure
    is variable (but not well modeled) - fuel fade, line
    drops, dirty filter, blah blah. You will probably have
    to fake one end of the other, idle or WOT, to get
    the result right. A manifold referenced, rail mounted
    regulator and some fat forward plumbing would be
    the fix for a lot of that.
    Someday.
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    It would have been NICE if GM would have spent a couple extra $$ like FORD did and actually MEASURED the fuel pressure but, alas, they didn't. So it is up to us to make and take those measurements and integrate them into HP Tuners.
    Always Support Our Troops!
    Not A Tuner
    Oct 2006
    977
    Quote Originally Posted by EC_Tune
    Doug
    So when everybody (not necessarily here) states 58 lbs for Vette feul pressure that in actuallity we need to measure it ??
    DH
    28,303
    Basically, yes. Fuel pressure does play an integral part in fueling obviously and when available yes you should see what is sitting at...the more you know the better off you'll end up being.
    Not A Tuner
    Oct 2006
    977
    For a shop with the right equipment this should be a really quick and simple task.....correct??
    THANKS
    DH
    28,303
    yeah...I think electronic fuel pressure gauges are only like $100 from autometer as well and can be logged right into hptuners as well so theres another option for ya
    Feb 2006
    Elk River,MN
    107
    Off topic but relavent to fuel injectors.
    Is the voltage offsets for fuel injectors. That confuses me the most.
    Like 60lbs'er are around .055 sec's at 14 vac. which is just one line of data on the whole table. What about the rest of the values??
    So what are stock injectors rated at then? My green tops are rated at 42lbs at 43.5psi. So if I offset that to 58 they are really 56lbs @ 58psi. So assuming the stockers are rated at 28lbs @ 58psi I would get a 0.5 multiplier. So do I then take that and multiply it against my closed loop proportional base vs. airflow mode? That is quite a change. I just want to be sure I am doing this correctly.
    Mar 2008
    Sothern California
    32
    Injectors rated 42lbs at 43.5psi would be 48.5lbs at 58psi. When you did the math you forgot to take the square root of the quotient before you multiplied.
    So, 58 divided by 43.5 = 1.3333333333. The square root of 1.333333333 is 1.1547000. You take that and multiply by 42 and you get 48.497.
    Jan 2005
    Concord, NC
    8,093
    Green tops are not rated at 43.5 either.
    Mar 2008
    Sothern California
    32
    Yes, the Ford Motorsports catalog shows the following "All injector flow rates are quoted at a delta pressure of 39.15 psi. To convert to a delta pressure of 43.5 psi, multiply flow rate by 1.054".
    Dec 2004
    Laurel, MD
    1,020
    you can believe some specs or you can believe empirical testing, your choice:
    http://redhardsupra.blogspot.com/200...vo-42s-is.html
    They are made by Bosch and rated at 43.5psi. So looks like your test data proves this and that they are about 49lbs at 58psi. So then it would be 28.8/49 to get a multiplier of 0.588.
