I have an 06 GTO with 60,000 miles. I've been logging random KR at WOT since having the cam in my sig installed. After running a test using Xylene to boost the octane, I've come to the conclusion that what I'm seeing is false knock. Here is my thread on ls2gto.com if you'd like to read the full story:
http://www.ls2gto.com/forums/showthread.php?t=223373
In my readings here, I've seen Russ Kemp state the following:
I see the Decay Rate table, but where / what is the attack rate table? Also, what risks do I run, if any, IF I'm wrong and what I'm seeing is real knock instead of false? I'm almost positive it is false because I can't hear it ping at all, but "almost" is sort of scary.Originally Posted by Russ K
Thanks,
Gerry
