Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
Thread: need a ? answered
    also this new beta is nice... we now have transmission controls and other new function that i don't know what they do.. but thats good. but we still cant change the tire ratio, but thats not really a big deal, we can live with out that.
    28,312
    Im able to change it up to 40in tall tires & 7.00 gears do you need to go higher?
    28,312
    worse comes to worse you just lower the gear ratio until your numbers line up using the 40" tall tires as the max height.
    error
    here is the error we get when we try to change the gear ratio. i am not sure what we are doing different.
    28,312
    Then you didn't download & install that version 2.2.1 I sent you
  6. #26
    Sep 2006
    Arizona
    600
    It is possible that your P0171 code came as a result of a fouled plug. I have experienced a fouled plug that caused a misfire before which resulted in a lean code on that cylinder bank.
    Fouled could also be caused by running rich. You may have the fuel injector flow rate off, resulting in a bad running condition. Usually when running really rich the plugs foul quickly.
  7. #27
    so i finally fixed the problem i was having with the hummer.All better now
  8. #28
    Advanced Tuner gman4dx266's Avatar
    Jun 2006
    Cape Coral, FL
    860
    What in the hell did you do?! I'm having a flash back!
    Looks like you got friendly with a new-jersey border.
  9. #29
    28,312
    Im thinkin he went rock crawling and made a wrong turn lol
  10. #30
    28,312
    Being an H3 with that much damage it is a total loss?
  11. #31
    Advanced Tuner redhotjamedjimi's Avatar
    Dec 2006
    Philadelphia, PA
    352
    Go lower!! Drive slower!!
    2006 SS Cobalt SC
    Stage 2 ZZP Cams
    Headers, 3.0" Full ZZP Exhaust
    60lb inj. Intake.
    2.8 Pulley
    72# Lb. Supertech Springs
    LNF Ext Valves and lashers
    Cobre H/E, option B.
    Torque Damper
    HPTuned.
    Bitchin'
  12. #32
    Advanced Tuner Programmer's Avatar
    Jul 2007
    244
    Really sorry to see that. Ouch !!
  13. #33
    Oct 2007
    Lawrenceville, Ga
    332
    That sucks! They seem a lot tougher in the video games
    BTW (not that it matters now) - on his scans, was I the only one not seeing O2 voltage? Maybe I configured something wrong in the scanner config...
    -Eddie
    1998 GTP - 3.4 [3.2] [3.0] MPS - custom CAI - F.1 Ram Air hood - Gen V - XP Cam - Ported Heads - 1.84/1.60 Si valves - 1.6 HS Roller Rockers - 72mm Ported TB - LQ4 MAF - 42.5# Lucas Injectors - Pacesetters
    1/4 PB - 13.025 @ 106.81 MPH w/ 2.069 60' (before Gen V or ported heads)
    2021 Chevrolet Colorado 2.8 Baby Duramax
  14. #34
    28,312
    p12 pcm's probably use a different PID than an 02 V8 camaro that the default config was setup for originally.
  15. #35
    miami
    34
    wow dude, nice.....
    howd that happen bro?
    i hope ur ok man!!!!!!!!!!
  16. #36
    Dec 2006
    Philadelphia, PA
    352
    look at his avatar seems about 3 secs from the wreck
    2006 SS Cobalt SC
    Stage 2 ZZP Cams
    60lb inj. Intake.
    2.8 Pulley
    Torque Damper
    HPTuned.
    Bitchin'
  17. #37
    I have my tuner and six credits for sale.Only asking 350.00.If interested call me 407 697 3969 name is greg thanks.
  18. #38
    Oct 2012
    24
    Can you upload the tune file i have a problem with a 2006 H3 turbo and i need a turbonetics tune to compare or if you cant send tome the tuning file to my email i apreciate very much [email protected]
  19. #39
    Dec 2008
    Nevada
    4,452
    i already mentioned you needed to talk to tech in your other thread. every engine setup is different and nobody will have a specific tune for turbonetics in general. you need a lot more information to get a tune that is even remotely close to what you are asking for. i would not expect anyone here to throw you a reliable tune. 90% of the people teach you how to do the work, most never hand it out for free.
    please talk to hpt tech to solve your connection issues first.
