Results 1 to 5 of 5
Thread: 2001 Pontiac GA requests
    Advanced Tuner xonelith's Avatar
    Oct 2004
    Whitby, Ontario, CANADA
    408
    Here's a few additions I would find helpful, mostly based on the 3800 guys requests and my failed emissions Note that my car is cammed.
    Based on some of the comments in a few other threads about VE tuning, I'd like to see a couple of extra tables to help with it, or to avoid needing it
    1. Selector for controlling the main airflow logic
    (http://www.hptuners.com/forum/showpo...77&postcount=6)
    2. MAF Low Frequency Threshold (low value in which MAF is disabled; useful to do VE Tune, so you don't have to unplug the MAF)
    (http://www.hptuners.com/forum/showpo...71&postcount=4)
    3. Not sure if there is something like this available in the PCM or not, but I would appreciate something to adjust afr at idle (based on my failed emissions test).
    Thanks alot!
    -xon
    All Motor 2001 GA GT1
    28,312
    We add it on a case by case basis currently, if you feel you must have the parameter added shoot support an email with the file you need it added for as well as your serial # & we'll add it. Many calibrations already have the parameter.
    O2 sensors will try to keep you at stoich no matter what you do to the vehicle so unless your trying to run an open loop tune(and even then you probably won't be able to command any leaner than stoich) there really isn't much else from what I could tell.
    Oct 2004
    408
    Quote Originally Posted by Bill@HPTuners
    Thanks Bill... I will send it later tonight!
    Stoich would be great!!.... I may have other problems though, but the o2 is new.
    How do you suggest to go OL during idle only? I want to continue with AE&DE for cruising so I don't want to go full OL. My understanding is AE & DE will be disabled if I go full OL.
    Thanks Bill!
    28,312
    email returned, you already have the parameter available in your calibration.
    Oct 2004
    408
    LOL... my mistake...
    Thanks,
    -xon
