I searched and couldn't find any related issues from others running a 160-stat
I’m getting a “X contact dealer” and it is related to the coolant temperature sending unit, since the temperature sending unit has bottomed out and the air conditioner cuts off. Have you all seen problems like that with running a 160-degree thermostat with these L76 engines?
The reason I ask if it is stat related is that it doesn’t seem to happen in stop and go traffic,, only cooler morning when I catch all the traffic lights,, or late evening temperatures when I go directly to the interstate. Could it be the coolant temperature is not rising fast enough? Data logs show temps dropping to 160 degrees when the car is rolling, climbing to around 190 in stop and go traffic. The times this has happened are when the engine may have never gotten over 160 for the first 10 minutes or so of driving.
Then again, it just might be a bad sending unit,,, stranger things have happened.
