for anyone that doesn't know what my setup is for the dune buggy, it's a genI sbc with stock large valve body heads and a good size cam (234/234 .5xx/.5xx). brand new rebuild with a 9.0'ish CR.
anyways, i've been fabricating a custom EFI ls-based system for it and i've come to the point now where I really need some help. I have no idea what kind of tune file I should start off with? maybe a 6.0 since it has a little more fueling? everything will function just like a ls1, except the motor at heart is the sbc350. I have all sensors and I do have a wideband and will upgrade to the pro interface before I start tuning (so I can log wb easily).
the firing order issue was sorted out by just editing it within hptuners, so no worries there. also, we've engineered a way to fit the reluctor ring and cam ring on the motor and have the sensors work properly
the pcm is a 2000 truck pcm and same for the harness. dunno what OS is on it right now. any help/suggestions would be great.
