Originally Posted by
engineermike
I think we're talking about two different things. There's the SAI torque reduction system that you are referring to, but I do not think the SAI system activates if the torque is simply more than driver demand. I believe the SAI system only works when torque reductions such as shift torque, traction control, deceleration, etc. are active, not driver demand.
I'm 100% certain there is an airflow PID loop, at least on the Gen3. Turning it off is the only way I was able to calibrate the TB model. I've observed des airflow vs MAF near-exact match with the PID loop on, then a steady-state error with it off. This has been repeatable on 3 different cars. The steady-state mismatch you mention could be due to a poorly calibrated TB model combined with not-enough span of control of the PID loop (there are limits). Or perhaps the Gen2 logic is different.
