2006 Corvette, LS2, E85 flex fuel, E-Force SC, 10 lbs of boost, PRC heads, 6L80E stock transmission. Dynojet numbers are: 682 hp @ 6,150 rpm and Max torque is 645 ft lbs @ 4,760 rpm. Delivered Engine Torque reads 456 ft lbs @ 4,760 rpm but should read in the neighborhood of 745 ft lbs. My tune is scaled (E38) because of the ID1050X injectors. I believe the scaled tune could be the reason for my low Delivered Engine Torque reading of 456 ft lbs. What do I need to do in order to bring my Delivered Engine Torque more in line with where it should read (in the neighborhood of 745 ft lbs,) ?
