Im going to be doing some work for a customer and he has installed the Holley intake with the 102mm TB on his 5.3. so now the mechanical fan is in the way of the air intake. He wants to go with either a smaller fan (dont think this is possible) or electric fan setup. Ive seen where you can buy the harnesses and run electric fans for GM truck and use these. Can you tune the ECM to turn the electric fans on? Or is there a better way to convert to electric fans? thanks in advance!!!
