Yes Gulf Coast Auto.... the log you ran there in your last post with exhaust cam angle desired at 128 and exhaust cam center position at 127, would most likely suggest that your timing is retarded by one tooth... But this only holds true if you logged these values above, and are running a cam phaser lockout in your build. And while I do understand that with each tooth that timing is off, it actually should be presenting this condition with a change of just over 2 degrees for every tooth its off... in each of the three occasions Ive come across this exact scenario, and it was later proven that timing was off by one tooth, the difference showing between either "desired" and "actual", or "desired" and "center position", was exactly 1 degree in all three instances. Why this has been the case, I haven't quite figured out yet.
