Results 1 to 7 of 7
Thread: MAP Sensor
    Feb 2021
    29
    MAP Sensor
    Guys when i swapped the intake to the TBSS on my motor it came with the MAP sensor PN12594942 what are the specs on this sensor i believe it was a 2007+ sensor. I had to change the plug on my harness to get it to work. With that said i found where it is MAP characteristics what values should i put in here? I found a mention of the settings should be Linear 128.20 and Offset -0.30. Is this correct?
    13,571
    It should be those because that's a 2009+ MAP sensor.
    Nov 2006
    2,751
    Quote Originally Posted by rwilson2510 View Post
    This is correct
    Tuner at PCMofnc.com
    7,680
    Go to parts site. Do a reverse search to find which vehicles used that sensor. Go to tune repository, find sample file for one of those vehicles, open file, find the correct linear/offset.
    Feb 2021
    29
    Ohh ok that makes sense. I did a test to see if the MAP sensor was working correctly and found the sensor was reading (28.9 inHg) (97.8 kpa) when the engine was off but key on. Shouldn't it be reading zero or a low voltage? I am asking because my harness didnt come with this sensor. My harness is a 2000 sliverado. What i am trying to figure out is when i replaced the plug to adapt this 2009+ sensor to my harness if i wired it correctly.
    13,571
    Roughly 100kpa with key on engine off at sea level is correct.
    Advanced Tuner Pulse_GTO's Avatar
    Apr 2008
    329
    Depending where you live that value is probably right.
