Originally Posted by
aaronc7
Is the MAF surrounded by metal piping? Trying to isolate it from direct radiant heat can help avoid some of these iat reading falsely high issues
I try to get multiple WOT runs in a single long log, and then use filters to remove transient data. Hopefully it's over 10 cells at higher rpm/maf flow areas, but I just take whatever I get at that point.
Ultimately some variation is normal and why LTFTs and closed loop fueling is used. I try to get a long 30 minute log if possible and as much good and varied data and just use the averaged out result. Once you to go +/- 5 percent you're starting to split hairs and could end up chasing your tail, IMO.
I can't open the logs right now to see how bad or inconsistent your data is though.
