How do you tell the difference between a vacuum reference tune file and a non vacuum reference file?
All fuel systems have a return somewhere. The difference is if it has a vacuum referenced regulator in the system with a return. If it does the IFR table will have the same number in every cell. If it doesn't the IFR table numbers will be sloped.
You're right. My question was worded poorly. so by what you're saying is the cell is consistent all the way across. It has a vacuum reference but if it's sloped it's a non vacuum reference tune file?
vacuum referenced regulator file?
Non vacuum referenced regulator file?
