Results 1 to 7 of 7
Thread: 0-90 ohm fuel sender tuning
    Feb 2020
    3
    I have a 97 trans am that I swapped an LS1 into. The gauge on the dash sweeps back and forth (when full) due to using the 97 and under fuel sender. I was wondering if this is tunable to read the 90 ohm sender correctly.
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,018
    if its sweeping back and forth while full, its likely a bad connection. the connections at the passenger foot well are notorious for problems
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Feb 2020
    3
    Double and triple checked all the wiring. Things are good there. I know the ohm reading from the sender I am using (0-90 ohm) is not the same what the computer wants to see (40-250 ohm from a 99 trans am). With hp tuners there is a fuel tab for the sender and gauge but I can?t make much sense of it, or know if this is a possibility to tune. Right now I?m using an auto meter gauge and would love to have the one on the dash working without replacing the sender.
    Quote Originally Posted by Bacajordan View Post
    If you're trying to read a 0-90 ohm sensor from the PCM using the Fuel level input then its a very wise idea to put a 47 ohm resistor inline with the sending unit to effectively make it a 47-137 ohm sending unit.
    The reasoning behind this is the Fuel level input is actually a monitored 5 volt signal from the PCM to the sending unit. The stock sending unit was at minimum 40 ohms, with out the inline resistor when your 0-90 ohm sender unit reads full at 0 ohms it would short out the 5 volt Vref on the PCM.
    Now of course you will have to do some calibrating of fuel volume vs % tables in the fuel tab to get an accurate working gauge with 137 ohm being empty compared to 250 ohm a stock sending unit would read on empty
    Aug 2021
    14
    any luck with this?
    Feb 2020
    3
    No luck? actually gave up on it until about a month ago. I bought a fuel gauge interface that is supposed to adapt any sender to any gauge, but my initial test wiring (today) didn?t seem to move the fuel gauge. I?ve got some wire tracing to do to make sure the sender signal is getting to the PCM, then PCM to gauge.
    Feb 2015
    Ms
    37
    im just curious here, this may or may not be able to help. if you are using the LS pcm, couldnt you seg swap over a van segment to be able tune the " Gauge Output " table for your particular sending unit?
