Results 1 to 17 of 17
Thread: IVT Terms with double stoich
    Jul 2022
    16
    hi all
    i have doubled the stoich and ifr too use bigger injectors am i meant too half the ivt terms also because i run e85 also my tune is uploaded thanks
    ill upload stock ivt and what i have done also how do i correctly half it
    thanks
    Australia
    1,990
    double stoich and halve IFR and halve IVT terms
    Jul 2022
    16
    half by .5?
    Australia
    1,990
    yes IVT terms should be like 7.92 standard multiply by .5
    Jul 2022
    16
    It was 3.96 stock is that right
    13,582
    3.96 means it was already cut in half.
    Jul 2022
    16
    Yea but it?s not ajusting the afr accordingly I have 26% of e85 but it?s sitting at 14.3 in gear at idle with the ivt term at 3.96
    13,582
    Yeah, the wideband will always read 14.0-15.0 if you are running E85 and using the gas scale read out on the wideband.
    You either just need to realize/remember that the wideband will still read fueling as if it was running regular fuel or switch to Lambda tuning.
    1.00 Lambda will read 1.00 no matter the fuel. Then leaner is above 1.00 and richer is below 1.00.
    Australia
    1,990
    the IVT terms is just so that the IVT temp reading is back to correct as many tables use it especially when cold starting and transients, its not an actual fuel correction value, as mentioned best to use Lambda if ur running flex and scaled, also some flex ecu have a varying IVT terms value u may need to find that and add in then halve so it works good for ethanol as well
    Jul 2022
    16
    Okay thanks so even at 25% of e85 it will still read 1.00 lambda?
    Okay thanks do you know where I could
    Find that? Cheers
    13,582
    Yes, Lambda will always read 1.00 for stoich no matter what percentage on alcohol is in the fuel.
    Jul 2022
    16
    Okay thanks
    Australia
    1,990
    i think some LSA tune files have the varying IVT terms for ethanol
    Jul 2022
    16
    Cheers mate
    Jul 2022
    16
    I used 2017 vf lsa ivt terms then halfed them is that correct ?
    Australia
    1,990
    should be fine
