So i got some help from a community member that helped a ton now im working on the dreaded p0300 random misfire issue. I have trouble shooted all aspects checking for false knock/false misfire. and eliminated all the outside factors. Compression equal and balanced across all cylinders, timing marks on plugs are barely visible. no vac leaks, fuel pressure is spot on. checked all the valve train all rockers are tight. My cam is the only thing that can can be causing the random misfires so thinking i need to adjust the missfire detection numbers. the random misfires are only at low idle below 1000 rpm and go away above that point. Which tables would i need to adjust to drecrease the sensitivity of the misfire detection as well as what to adjust in the knock sensor levels. Ive come across several posts about adjustments in various tables but the posts were older, also i was confused on which way to adjust on numbers up or down depending on the table. i dont want to fully turn off knock sensors in case i get some nasty fuel or true major knock. I just know i can see timing being pulled due to the false knock. ive attached the current tune and data log. part way through the log i did another CASE relearn to make sure.
I have a BTR stage 2 truck cam SPECS: 212/218 .480/.480 111+0 GM perf .550 springs Btr Trunion upgrade on factory rockers.
Summit racing shorty headers 1 7/8 primaries
factory lm7 intake. stock injectors
factory 823 heads fully gone over minor port work. just smoothing/polishing. stock pitons, gen 4 rods. stock flex plate/converter.
advise appreciated on which direction to go. im learning trying to research as much as i can before posting. one thing i havent been able to find is which way numbers go in tables to increase things or decrease things IE decrease sensitivity in the knock sensor global gain and or any of the associated tables affecting the knock sensors or the misfire detection.
thanks for any help and smooth running to you all.
Tahoe67-base.hpttahoe67-base.hpl
