Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: 11 ctsv lsa stalling and too rich in drive
    i have a 2011 ctsv, stroker 383, cammed, cai and full headers no cats.
    car has decent tune i already did the maf runs great on that section.
    now im tuning sd and disabled maf, getting stalling from idle when i accelerate. sometimes itll slowly climb up.
    itll rev up fine in park. have logs and tune attached. any help is appreciated.
    thanks.
    updating w new file, includes new vve table and eq to 1.16
    7,643
    I'm not sure, but I don't think negative nineteen billion is a valid number to put in the VVE table.
    i know, but is anyone ever going to hit map 100?
    7,643
    100kPa? You're most likely at 100kPa right now, sitting in your chair and breathing normal 100kPa atmosphere.
    Tuning Addict
    Jan 2015
    6,804
    Yeah, anything above 100kpa is usually boost and yours is boosted, so your basically taking all of your fuel away when getting into boost. You even have (-) values below boost in higher rpms. Go back to a stock VE table and adjust from there. Not sure why you started with a flat cut table anyway unless fueling is scaled incorrectly?
    ~Greg Huggins~
    Aug 2009
    Calibrating
    3,373
    Bahaha this made me laugh
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    ok my vve table maxes out at 105kpa. i have a feeling thats missing more rows down there. when i do zones the lower zones are not showing .any help is appreciated.
    Tuning Addict
    Jan 2015
    6,804
    You have a 3ish bar VVE table from factory. Just click on the axis on the left then click the second one. Should be the most boost you'll see with that lsa blower on a bigger displacement engine anyway.
    ~Greg Huggins~
    Tuning Addict
    Jan 2015
    6,804
    Start with this - should be closer. I only put in the open and closed tables - didn't look over any of the rest of the tune or mod anything else....... If you so wish you can change the axis back and forth and more finely dial things in too.
    ~Greg Huggins~
    7,643
    Those PE settings look kinda... dangerous? Disabled below 5k then at 5500 it drops to 1.18?
    got the vve table fixed, this is a great learning process. set eq to 1.16 for now have a very nice idle.
    going for a test drive soon. uploading new file to OP
    Tuning Addict
    Jan 2015
    6,804
    You might want to go the opposite way on that. Your stoic is 14.700, so 14.700 / 1.16 = 12.672 = good for NA, but not boosted. You'll want something more like 1.22 or a 12 afr or even a 1.26 for an 11.66 afr target. 12's fine, but you better know what your doing or at least on a dyno to measure gains/losses... You'll also want to keep your VVE table smooth - especially in boosted areas - that dip will affect from idle to wot transient stomps
    ~Greg Huggins~
    Nov 2009
    All Around
    3,149
    your log and file is screwed royally
    i responded to your email file is ready
    Quote Originally Posted by SultanHassanMasTuning View Post
    I asked you for a price. and you responded $400usd. no way, i pay that for local dyno tuning.
    im trying to learn, thanks though.
    thank you , thats a great help. keep yall posted as i move along
    Feb 2018
    824
    Quote Originally Posted by dually681 View Post
    He's charging you $400 bucks for a tune? That's pretty decent price man...I don't know why you think that is so expensive considering all the time that goes into learning how to tune. I started tuning my ctsv myself in 2018 and I'm still learning shit 4 years later..just to give you an idea of what you are up against.
    Feb 2018
    824
    definitely richen up that eq ratio..12.6 with a roots blower is getting pretty lean..and that's assuming that you airflow model is correct. It could be even worse if it's off and you go even leaner while WOT. Guys typically run these cars from 11.2-11.8 afr
    Nov 2009
    All Around
    3,149
    owner of thread wants a freebie
    reason why i charged that is that the file is a complete MESS
    dyno tunes are great but dont address your daily drivability concerns
    dailing in a car takes time, i doubt you will pay hundreds of dollars for that on a dyno
    Feb 2018
    824
    I don't think that's unfair at all considering alot of guys charge more than that for a tune for the ctsv
    Aug 2009
    Calibrating
    3,373
    Totally fair price… would have been better then his local dyno tune most likely too
    14 Gen 5 Viper
