Just put a little baby cam in a l76 222/234 .600/.575 115+3, got the wideband installed and I'm seeing 15-15.7 at idle. Currently has E50 on the tank with a flex sensor, that was to my knowledge working just fine before the cam.
ECM is commanding 11.8afr but not according to the wideband. Stft run in the -3 range ltft are closer to zero. Just for the hell of it I I added 30% on the maf table started up and saw a better 12.2afr but it immediately pegged the fuel trims and threw a CEL for the map sensor..
