Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
Thread: supercharged lt1 with ls1 computer maf question
    Oct 2008
    Mebane NC
    475
    I used the knock sensors for a 96 LT1
    Jun 2016
    Tuscaloosa, Alabama
    71
    60's are in and its running. wideband is showing 11.7 -12.6. sd error for ve histogram still shows negative. I have reduced it 2 times and it still shows 11 - 12. Of course its idling better with iac at 70 to 80 and timing around 20 - 23 degrees. Im not sure but I dont think the table is supposed to be that low at this point. eq ratio is set to 1.00. and stoic set to 14.63(what it was to start with never changed it). headers are 650-700 degrees also. I have had some cams with low numbers on the ve table before but not lower than mid 50's. If it takes more again it will be mid 40's. just doesnt seem correct. Am i missing another variable now that i have changed to sd?
    Jun 2016
    Tuscaloosa, Alabama
    71
    forgot to drop these on the last post.
    Aug 2009
    Calibrating
    3,373
    Fuel minimum must be at .028 still…
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Jun 2016
    Tuscaloosa, Alabama
    71
    running but failing
    so im back to working on this lt1-ls1 conversion. I have gotten it drivable. I am working on the ve table and am having a hard time figuring out what is going on. no matter what i changed on the ve table it kept showing eq err at -16 or more. But also as i moved up in rpm those numbers got closer to 0 and the car went lean. so i started over with a new ve table. I created one from scratch with 35 as the 15/400 block and 125 as the 215/8000. once running the eq err got closer and numbers were staying higher as i moved up the rpm range. i have added 30% to the ve table over what it was originally and have gotten it to run up to 4300. but at 4300 it pops and goes way lean. i have tried adding more ve to it but this is as far as it will run under load.
    first tune and log is before the full change of the ve
    ve tune 1.hptso running throttle movements.hpl
    second one here
    popped_lean at 4000.hplve tune 2 total change tryout added 15per more at 145 up.hpt
    i am trying to figure out what is going on now. I just had a thought that if all these other parts were not feeding it properly that the fuel pump probably isnt either. no where for a pressure gauge on this rail that they have on here though. hopefully though i am running the right direction on the ve table.
  6. #26
    2,745
    Quote Originally Posted by CranknChrome View Post
    second one here
    I'm sure someone mentioned this before... but your transient mins haven't been zeroed out. This caps the minimum amount the injector will fire as map bounces around.
    Some people will try to tweak this number.. I've never ran into issues just zeroing it.
    NOTE this will change your tune by quite a bit.. Prepare to take a step backwards. but you should be able to get where you need to go after.
    transient mins removed.hpt
    Tuner at PCMofnc.com
  7. #27
    Jun 2016
    Tuscaloosa, Alabama
    71
    I had dropped it from .048 to .028 when i changed to the deka 60's.
  8. #28
    Aug 2009
    Calibrating
    3,373
    .028 is factory value… needs lower
    14 Gen 5 Viper
  9. #29
    Jun 2016
    Tuscaloosa, Alabama
    71
    10-4 Ben
  10. #30
    Sep 2009
    764
    Heads up..
    I've never seen knock sensors work on torque head or EFIconnection swaps. They always report nothing even with audible knock.
    From college I know knock sensors are tuned to pickup on the ringing in the combustion chamber which depends on bore size and the speed of sound in the mixture and some other things. Perhaps not being able to tune knock sensors for a particular frequency is what causes it not to work.
    My knock sensors worked perfectly with EFI Connection but they were dual L31 Van knock sensors on a 24x L31 van.
  11. #31
    2,745
    Quote Originally Posted by Fast4.7 View Post
    Thats interesting.. thanks!
  12. #32
    Sep 2009
    764
    No problem, IIRC the older OBD1 knock sensors have the wrong resistance values for the 0411. Need to use L31 Vortec which may have also been OBD2 LT1 sensors. I am afraid to say for sure on the OBD2 LT1 stuff because I am not sure what GM used there.
  13. #33
    Sep 2017
    736
    Heads up..
    I pick up knock with my torqhead set up.
    My issue was the scanner was reading average knock when I should have been looking at max knock.
    Could be other calibration reasons but that was my experience.
  14. #34
    Jun 2016
    Tuscaloosa, Alabama
    71
    pulled this one back out
    Pulled this back out of the back of the shop. Its running in sd. I have cut out 20% more in the ve around idle. or at least what the histogram is showing for idle. wide band and the commanded are not getting any closer. what am i missing?
    lamda not matching commanded.hpl
    cut 20 out to see.hpt
  15. #35
    Mar 2011
    Ripley, MS
    1,865
    Some of the PID's aren't making sense. At 36.33 secs into the datalog, it shows 113kPa on the MAP sensor reading at 2760 rpm and 17% TPS.
    At 1:03.43 into the datalog, It shows 40.9 kPa on the MAP at 2741 rpm and 29% TPS. That doesn't make sense. I suspect that there is just too many PID's on the datalog and is just slowing it down. You might delete any of the unnecessary PID's and while you're at it, make sure that the sampling rate of the PID's are consistent.
  16. #36
    Sep 2017
    736
    Your continuously getting the same wideband reading and or histogram readings you're historian or wideband isnt working correctly. That or I'm reading somthing wrong
    I'm going to assume you have cam in the 220/230s range. If so your tune is close to what mine is and mine runs perfectly fine.
  17. #37
    Jun 2016
    Tuscaloosa, Alabama
    71
    242/236 and .502/.520 114 lsa
    Kevin has been helping me figure it out, we changed boost enrichment, eq ratio tables, injector tables. Then the idle a/f ratio leaned out where it was closer to where it should be. Got it to actually make a decent pass and got to fill some cells on the afr err yesterday and was making progress until today when it decided to go full lean at idle on bank 2. Which bank 2 is where the wideband is located. So I know something has messed up on that side now. Motor had to cool down before I started pulling plugs and bank 2 o2 sensor so ill get back on it in the morning. Posting the last run and tune file for it. It idled funny at the beginning then straightened out and so I ran it. At the end it started to bounce around on the B2S1. Also had just filed with 10gals of 93. Fuel pressure gauge was still on about 44psi.
    ve change after load pull on dyno.hpt
    a few pulls at constant load not wot.hpl
  18. #38
    Jun 2016
    Tuscaloosa, Alabama
    71
    Changed O2 sensor out and didnt change anything. Pulled the top off the motor and got back down to the injectors and pulled them out. Found crystalized fuel in 6 and 8 and also some gas jelly. cleaned out fuel rail and injectors on the bench. Its better but O2 still bounces in and out causing it to go .90 to 1.13. before this it was pretty spot on consistent.
    Now I am getting a P0352 code. Think this may be causing whatever it is. So I pulled number 2 coil and swapped it with number 4. still got 352. Checked wire for continuity back to ecm. checked out good. visually checked wire through loom. again had to pull top off. all checked out. cleaned pins. tried it again. 352.
    What else can it see to pull that code?
    bouncy.hpl
