Results 1 to 20 of 21
Thread: Read Me!!! Tuning How-To's & General Information
    Nov 2007
    Considering VCM Suite
    Bill, I have a 2005 C6 (6 speed mnl, Z51)....just completed following mods:
    Kooks long tubes, XO and hi-flow cats
    Corsa sports
    Vararam with TB spacer
    Ported intake & TB (FAST is next)
    160 thermostat
    Ignition upgrades
    Gears coming
    A few more planned
    I am seriously considering the HP Tuner Product, but have a concern.....
    Here's the situation:
    Originally I bought that other manufacturer's "blue handheld tool" to modify the tune accordingly. To say the least, I had some issues and have requested an RMA to return the unit.
    In summary - here's my concern....
    -When I connected the other manufacturer's tool to the OBD-II port and went to "Performance Tune" it displayed; "12605740 - part number not found in vehicle database".
    -Spoke to their Tech Support guy and was told I had an "unsupported earlier version" factory program and would have to have the dealer reflash to the latest revision.
    -Like a dope, I took the car to the dealer (used the battery run-down complaint) and had the reflash done.
    -When I returned home, I connected the "blue tool" again and got the same message....was not a happy camper.
    -I've already requested an RMA to send this "tool" back
    IMO - if a manufacturer says the tool will work on the 2005 C6 LS2, it should. I shouldn't have to be negotiating with the dealership to perform flash upgrades on a car that has performed flawlessly since the day I bought it.
    Bottom line:
    1) Is this "unsupported earlier version" thing going to be a problem with the HP Tuner product as well?
    2) Will I be able to restore my factory tune for dealer servicing?
    The car only has 11,600 miles on it, still has 8 months left on the factory warranty, and I'm certain I've already raised the dealer's curiosity.
    Your thoughts???
    Clermont, FL
    22,585
    As long as it IS a valid operating system for your vin number we will allow you to tune it, whether we've seen that operating system previously or not we will add it if need be but YES if it is a valid file for that vin we WILL support it PERIOD.
    I am trying to follow the steps outlined in the SDTuningGuide.doc in the above link. I am not sure if I am interpreting step number 4 correctly. It sounds as if the document is telling you to replace all values in the corresponding tables with a value of 1 to simplify the math and for logging reasons. I tried that and the vehicle barely runs. Did I mis-understand this step?
    Thank you.
    Advanced Tuner Braciole's Avatar
    May 2008
    New Jersey
    227
    Quote Originally Posted by c6goanth
    Corsa sports
    160 thermostat
    Ignition upgrades
    Gears coming
    A few more planned
    Bottom line:
    Your thoughts???
    wow I have the same car in an 07 scary LOL
    and I am looking for the cheapest price on HP Tunes too
    2007 C6 coupe LS3 416 6 speed mn Z51 3LT
    Vararam Snake charmer 160 Stat
    Kooks 1 7/8 headers with jet hot
    Fast 102 ported intake 102 TB RPM Level 5 T56
    MGW short throw ZIP 4.10 Severe Duty rear
    RPS TWIN DISC CARBON CLUTCH CCWs ele wp
    RPM LEVEL 5 TRANS W/HARDENED OUTSHAFT
    http://www.youtube.com/watch?v=PtOPy_lp2QY
    10.66 1.47 60ft 133+mph
    Aug 2008
    Active handling
    We would like to be able to shut off the active handling in my car. Is there any way to do this?
    Peter
    Advanced Tuner angrygoat's Avatar
    Oct 2008
    New Baltimore, MI
    356
    injector spreadsheet question:
    it shows that the injector flow rate changes with MAP. This is only accurate if you are running a vacuum/boost referenced regulator correct? If you regulator runs straight off of atm, the flow rate will always be constant right?
    Joe
    2006 GTO
    APS TT
    10.76@135
    Only engine mods were near stock cam and valve springs
    "The goal of tuning is for the tune to run well enough you dont need any corrective mechanisms"
    Tuner in Training Ironmancan's Avatar
    May 2008
    Jacksonville NC
    43
    I have windows vista and for some reason I cannot open the Rough LS2 E40 pcm VE tuning How-To file. Any suggestions?
    06 Twin Turbo GTO
    May 2008
    Jacksonville NC
    43
    ROFL, thanks? lol....
    06 Twin Turbo GTO
    May 2008
    Jacksonville NC
    43
    ROFL at some of the responses. Got it figured out, thanks.
    06 Twin Turbo GTO
    Tuner in Training mcm1209's Avatar
    Jun 2009
    49
    I have searched and searched and googled but no luck
    How do i log ETC?
    2009 GMC Sierra All Terrain Z71
    Senior Tuner Google's Avatar
    Sep 2010
    Saint Peters, Missouri
    1,303
    Quote Originally Posted by mcm1209 View Post
    How do i log ETC?
    right click on your table display... find your throttle position.. add it to your table display.
    ETC = electronic throttle control
    if it is working then you will see tps position changing when you move the throttle..
    EDIT********************* Log all TPS Positions and find the one that reads 100% at WOT and 0% with no throttle movement..
    We Can Fix Your Bricked PCM Or Your YYYYYY OS ID
    Jun 2009
    49
    Thanks ill try that
    Jun 2010
    326
    What program should i have so i can view the tuning doctor? Im trying to open it but it dont work.
    Jun 2009
    12
    Some Of The Links Are Not Working
    Please Check
    Aug 2010
    28
    Quote Originally Posted by slyb28 View Post
    Please Check
    Still the same. Not working.
    Sep 2013
    Link to Flex fuel stuff was working until yesterday, now the whole thread has disappeared: http://www.hptuners.com/forum/showth...061#post322061
    Could we get it back, please?
    Clermont, FL
    22,585
    Quote Originally Posted by barum View Post
    The thread was deleted by the original poster, only they can restore it and I can only assume if they wanted it deleted that they aren't going to restore it.
    Tuner in Training TexasGMC08's Avatar
    Feb 2013
    48
    Injector Spreadsheet not working.
    Clermont, FL
    22,585
    Just tested, works fine for me.
