Results 1 to 7 of 7
Thread: LS7 Does strange things, here is a Log file
    Tuner in Training stevegressel's Avatar
    Jan 2022
    Syracuse, New York
    11
    Sometimes my car will hang the throttle when in neutral. for instance, driving down the road, put in neutral, rev engine, and it hangs for 5 to 10 seconds. check 19:07:45 area in the log.
    GM Stage 3 cam, all the other supporting mods.
    any advice would be great.
    thank you
    DRIVE 1.hpl
    OriginalZ06Tune.hpt
    Jan 2008
    242
    You started new post ? Why ? check your old one .
    Jan 2022
    Syracuse, New York
    11
    This is a new issue i came across today.
    Aug 2021
    847
    just glanced at your Base Running Airflow and it is higher than boat dock gas. id start by lowering it quiet a bit. that will help with throttle hang.
    Jan 2022
    Syracuse, New York
    11
    I made a few changes to base running airflow, didn't seem to help much for the throttle hang on a rev (downshift rev).
    Still have a few issues,
    1) Idles up to 2000 or 3000 RPM when coming to a stop, then immediately drops to 1000 when the car stops. (very annoying / embarrassing when in traffic and the car starts revving to 3000 rpm while coming to a red light / stop sign.)
    2) Throttle hang when hitting the gas, it wont just rev then come back to idle.
    3) Still has a lot of cam surge at lower RPM.
    4) Doesn't start unless I hold throttle pedal to the floor.
    5) Doesn't want to shut off.
    here are some logs and the tune.
    Drive 3.hpl
    drive 4 cruise - bad shut down.hpl
    Drive Home 5.hpl
    Z06Tune1.hpt
    2009 Z06 with LS7
    Quality Motorsports Stage 3 Cam (248/265 114+2LSA .650 lift)
    FIC 60lb injectors
    Halltech 108 air intake
    MSD Atomic Airforce Intake
    Nick Williams 102 Throttle Body
    Walbro fuel pump
    Aug 2021
    847
    see if this helps with your hanging idle. I was not able to view your logs. For whatever reason, it kept telling me that i cant view the log unless i upgrade to a newer version. Z06Tune1-braf.hpt
    Tuning Addict
    Jan 2015
    6,815
    You might also want to change transmission shift airflow - p/n - to 1's.
    I see hpt's at it again - forcing updates on everyone. I'm still not updating this computer!
    ~Greg Huggins~
