I'm tuning Kenne Bell charged 3V engine, and I'm trying to correct torque tables. I have MVPI1 Pro, and I have real torque signal from Dynomite chassis dyno in input 4, PLX map/boost in input 4. Am I correct that I should put data in Torque model - engine torque? In datalog threre is quite large IPC torque error values.
I use driver demand table from same year GT500.
Same challenges there are, it has Bosch modified 1000cc injectors that I can't find correct parameters. Maf is PMAS HPX-E, and there is plenty of reserve. Voltage went only to 3.2V
Boost is 125 KPa max, engine is MM built with locked custom cams. Hellcat fuel pump, I got that working ok.
Attached tune, and log. Log is not the latest and doesn't include real torque data
1.hpt 5r.hpl
