Hello! I have been watching videos, reading the forum and trying to learn as much as possible as I get ready to fire up the family hauler for the first time since installing a brand new crate engine from GM Performance. I know I need the vehicle tuned for the new engine and after doing some research, I think I got this. Although reading some of the horror stories in the forums has me a little scared.
Here is what I have...
GM Performance LS364
Holley Low ram intake with 36lb injectors
Stock throttle body with adapter
Pacesetter long tube headers
K & N cold air that was on the truck previously
Stock sensors
No exhaust hooked up yet- will do it as soon as the truck is up and running. I will add high flow cats and new magnaflow or flowmaster muffler.
The differences between the factory engine and this crate engine are...
Old Motor_____________New motor
Compression 9.4 ___________ 10.3
Cam lift .467/.479 ______.550/.550
duration 196/207 ________204/218
HP 330 _____________452
I don't want to be lean on initial start up and break in of the engine. I just want to be "safe" for that period of break in. The cam is close to the stock cam and I am hoping I won't need too much timing adjustments in the beginning. So my question is...
Do I just need to change the injector size info in Hp tuners? or do I need to richen the entire fuel map as well? I know that I will disable the post cat o2 sensors and put the computer into open loop to get things running. I have also purchased an AEM wideband to go with the recently purchased Hp tuner pro that I will install as well. Any suggestion to basic configurations before the key gets turned for the first time would be greatly appreciated!
