Results 1 to 6 of 6
Thread: P0106 on a cammed G8
    Jun 2018
    609
    I hate to just turn codes off. Does anyone have a suggestion on how to get around this code or what code be causing it? Mild cam on a G8
    Aug 2009
    Calibrating
    3,373
    What is map reading key on engine off and then running?
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Tuner BigTuner's Avatar
    May 2020
    Indiana
    111
    The code is usually triggered by a cam as the idle MAP reading is different to what is expected from OEM. Depending on the OS you may be able to adjust the threshold values, if not you will either have to disable the test via a temperature range change.
    Jun 2018
    609
    It's running around 98 when it's off and mid 60s at idle. I was just wondering if everybody just disables the code on cammed cars or if there is something else in the tune I should be tweaking. How would one adjust the threshold values.
    May 2020
    Indiana
    111
    To turn off the tests go to Engine Diagnostics > Airflow , there will be temperature thresholds for the P0101, P0106 and P0121 codes. If your OS can adjust the thresholds there will be the option to change P0106 MAP test max and P0106 MAP test min.
    Jun 2018
    609
    Yeah, that's what I've been doing. I was just looking to see if there is something other then turning off the tests. Thanks guys
