Results 1 to 18 of 18
Thread: 2010 sierra 6.2 btr stage 2 truck cam stalling issues
    Mar 2022
    8
    park to d/r-stall(intermittent)
    deceleration-stall(intermittent)
    stab throttle-stall (intermittent)
    Had the truck tuned by a very popular tuner, has 26-28 stall converter btr stage 2 truck cam some slight head porting and headers(no cats) vvt delete
    Truck likes to stall when slowing down for turns from normal driving
    also sometimes from park to reverse/drive
    also stalls from stabbing throttle in park while trying to come back to idle.
    I bought HP Tuners to try and fix it myself. I am a mechanic by trade but tuning is a bit deeper. I see its pulling large amounts of fuel out at high rpm, possibly flooding? MAP or MAF issue? Read somewhere about possible throttle follower issue? I am also slightly concerned with the dramatic difference in fuel trim between bank 1 and bank 2 under load. No engine codes.
    Tuning Addict
    Jan 2015
    6,814
    You need to post the tune - just looking at the log your fueling wasn't tuned in worth a flip. You might also want to check plugs and wires on bank 2 - looks like it's misfiring (bank 2's fueling is close with no load, but the second you put a little load on the engine bank 2's fuel trims go substantially different). Other things to cause this issue are things that cause misfires - valvetrain, injectors and so on, but also ignition timing in the tune and injection timing. If this tuner is supposed to be good - looks like he would have seen some of this or tried to dial things in?
    ~Greg Huggins~
    Mar 2022
    8
    current tune
    212/218 .553"/.553" 111 LSA cam specs
    Runs fine other than the stalling, heads were gone through new lifters, stainless exhaust valves, springs. At idle it is extremely choppy. If I obdII my Modis Scan-tool and open misfire monitor i have zero misfires. I thought the same thing. I've never tuned anything but these MAF g/s numbers seem high to me from what I'm used to.
    Tuning Addict
    Jan 2015
    6,814
    Didn't mess with fueling other than your VVE table - didn't look like your vve was dialed in at all, which will effect the issue your having. I also made quite a few changes to your idle settings and some to timing as some of the settings your tuner put in were questionable at best - should take care of the majority of your problem... HPT apparently isn't allowing you to kill misfire codes anymore, so couldn't see if they've been turned off or not. I still think you have a bank 2 problem you might want to look into a little deeper. Since all of the head work was done, has a cylinder leakdown been performed and were pushrods measured?
    ~Greg Huggins~
    Mar 2022
    8
    Thanks for your time, I'll let you know! Stock pushrods were inspected and re-installed. This cam calls for factory length pushrods according to BTR. No on the Leakdown test as I thought it wasn't misfiring(based on scantool data). I will Look into that also. I put the cam kit in initially because bank 2 had a dropped valve seat on cylinder 4 and the heads needed removed anyways. I think it was tuned before I purchased and they turned off MiL. The engine was running extremely lean. There was no surface damage to piston when I rebuilt the top end.
    7,649
    Post O2 Test & Catalyst Test are still enabled, but everything else in the tune says those components are no longer present. These are settings that have been recently removed from the software; I can see them because I'm still on an old version.
    Mar 2022
    8
    @blindsquirrel So you're saying I should disable those? The truck idles much better now, no stalling. Some slight popping on heavy accel but i'll check into that.
    7,649
    Yes. It will still do some weird shit to the mixture under certain conditions for those two tests, even if the DTCs for the regular diagnostics are disabled.
    Those tests can cause issues during tuning (bad data) even if the plan is to keep cats & downstream O2s intact afterwards. If they're removed you for sure don't want it trying to run those tests ever again.
    Mar 2022
    8
    Alright I'll do that and see what happens. Wish I knew what you guys did would make this much easier. If I can find it lol
    Tuning Addict
    Jan 2015
    6,814
    This one has cat test disabled - Thanks Again blindsquirrel
    To see what all was changed - open your original file then open the compare file - everything changed will be different color.
    ~Greg Huggins~
    Mar 2022
    8
    Is that one different than the last one you sent me, or is that the last one you sent me? I don't see any differences between that one and the one I compared to last night? VCM doesn't show me anything in engine diag on your sheet, unsure if that's where you made changes. Literally a blank sheet.
    7,649
    The stuff he changed isn't visible in the latest version of the editor.
    Mar 2022
    8
    well that is unfortunate haha
    7,649
    Mar 2022
    8
    what version of VCM is that? I wonder if I can get an earlier version somewhere
    7,649
    4.8.7.0
    Nov 2020
    24
    Where can I find that version?
    7,649
    The folder on your hard drive where you archive old software versions, after giving them proper filenames so you can differentiate one 'VCM Suite.msi' from another 'VCM Suite.msi'?
