Results 1 to 3 of 3
Thread: can a gen 4 ecu be made to run a gen 3 engine?
    Aug 2020
    6
    Hello,
    Customer brought me a 07 silverado needing engine/trans replacement. 4l60 4wd square port AL 6.0 equipped, he bought replacement engine/trans 4l80 cathedral port iron 6.0 from an 02 and he's asking if the 07 ecu can be made to run the replacement engine.
    Thanks all!
    7,643
    If it's an '07 Silverado Classic with a P59, yes. If '07 Silverado with E38, nope, not unless you pull the crankshaft and change the reluctor wheel.
    Learned the hard way about this same issue, at least crank isn't hard to pull and swap the $35 reluctor wheel, crank sensor,$35 4x cam gear, and drill and tap new holes on block bungs for gen 4 knock sensors, had to clearence passenger motor mount tho to not hit knock sensor. I believe there is a adapter harness from gen 4 to gen 3 knock sensor but don't quote me. Good time to add a oil pickup tube bracket ( two bolts vs one bolt hold down) also. Was told I needed a jig to place reluctor wheel properly, but I made a video how I did it, worked great zero timing issues.
