Results 1 to 14 of 14
Thread: Please walk me through W/B MAF tuning
    Feb 2006
    Warner Robins, GA
    202
    Quote Originally Posted by foff667
    this is about as good as it gets for step by step instructions right now http://www.hptuners.com/help/vcm_edi...to_user_sd.htm if you have a more specific question concerning it let me know & I'll try to explain it better. MAF tuning after your done VE tuning is pretty simple really its just a matter of enabling the maf & seeing how much your afr has changed since your VE is dialed in, dial in the maf in a near identical fashion as the ve table(using the copy-paste special-multiply by xx method)...once thats dialed in within a 2% or so just set it the way you want, closed loop maf or open loop maf, etc and your done at that point.
    Where do you locate the "Air Fuel Ratio Commanded Hi Resolution" PID? I only see the Lo Resolution PID under Fuel
    2005 Pontiac GTO LS2
    MY FQUICK - http://www.fquick.com/cyclone_chris
    Mods:
    K&N Intake | 18" Staggered TSW Thruxton Setup | Toyo T1-R Tires | Billet Products Short Shifter | Kooks 1-3/4" LT Catted headers | NGK TR55 | Ported Stock Intake Manifold | Corsa Sport Exhaust | Polished T/B | FlowTech Streetsweeper V2 Cam | SLP UD Pulley | 160 Thermostat | LS7 Clutch | 39# Ford Blue Giant Injectors | Scorpion Roller Rockers |
    445 RWHP/413 RWTQ
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    some cals use high, some low...ls1's use high, all ls2, ls7, some i4, i5, i6 use low...in the end your getting the same info, just a different name by gm.
    Feb 2006
    Warner Robins, GA
    202
    From Help File
    Load the MAF - AFR Error.hst histogram.
    Make sure you log MAF in Hz in the table and go for a drive.
    A problem I have is when I load the MAF - AFR Error it says Table Unsupportedin the histogram config options.
    Is it because the LS2 motors have a Hi and Lo MAF Freq table? If so a note in the help file would be awesome.
    These are the MAF Tables I have available
    Mods:
    445 RWHP/413 RWTQ
    HP Tuners Support
    (foff667)
    28,268
    yes, different applications call for different tables...use the maf hi & low & you'll be fine.
    HP Tuners Support
    (foff667)
    28,268
    http://www.thetuningdoctor.com/HPTun...ustomHisto.swf
    heres a flash demo i made...it gives I5 colorado's as an example since they have like 5 ve tables many of the default histos dont work.
    Dec 2004
    Laurel, MD
    1,020
    Quote Originally Posted by Cyclone Chris
    LS2 GTO's have only low res
    Feb 2006
    Warner Robins, GA
    202
    It would be awesome if we had more LS2 E40 How to guides or Demos on tuning. Are there any??
    Mods:
    445 RWHP/413 RWTQ
    HP Tuners Support
    (foff667)
    28,268
    make some & either submit them to support or me & I'll make sure they either get stickied or in the help file.
    Fact is im not big into tuning LS2's so its all user submitted.
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Use this config file, just insert your brand of wideband in place of my FJO in the table display.The histograms are set up for the low & high maf tables. Also insert Dynamic Cylinder Air (g/sec) in the table display. (I had the scanner last hooked up to a 24 bite car and ran out of room)
    Russ Kemp
    Feb 2006
    Warner Robins, GA
    202
    If I was a pro at this I would. Unfortunatley , I'm still learning.
    Mods:
    445 RWHP/413 RWTQ
    Feb 2006
    Warner Robins, GA
    202
    Quote Originally Posted by Russ K
    Russ Kemp
    Russ, I really appreciate it. I'll have to buy you a beer if I ever met you.
    Mods:
    445 RWHP/413 RWTQ
    HP Tuners Support
    (foff667)
    28,268
    Neither am I, I learn something new everyday in reality...what exactly are you looking for though? Maybe I can dig up some stuff & sticky it in the meantime.
    Feb 2006
    Warner Robins, GA
    202
    Well, I have seen the SD Tuning Help file, which is outstanding, but I was kinda confused, when certain tables or charts were not available on the LS2.
    I kinda call myself a perfectionist when it comes to adustments and such. I guess I can blame the Air Force for this... don't know how many times they hammered it into our heads that we constinantly needed nominal values for our F-15 Radar Systems.
    What I'm trying to figure out now is, Should I first do the Maf tables, or VE tables first? With Russ's Config file, what do I look at, LTFT or AFR Error %? How do I apply the changed to the Hi / Lo MAF tables to get nominal Values? Once the values are applied, how do I confirm them? What are the max/min acceptable %error?
    I guess these are the questions of a newb like myself. I really hate asking these questions cause I'm sure most of you guys have heard them over and over, and after a while it becomes really annoying.
    Thanks for the help.
    Chris
    Mods:
    445 RWHP/413 RWTQ
    Feb 2006
    Warner Robins, GA
    202
    I always leave the VE table stock when doing a Maf tune. Make sure that your in open loop and reset the fuel trims. Set the commanded PE to 1.13 (13.0 afr), and rescale the Maf using the Maf histogram AFR Error%. Slow the car down to 1000 rpm in 3rd gear, then go WOT till your redline. Then copy & paste the error% to the Maf table. For any maf cells that were skipped over, average the values & enter them into those cells.
    Russ Kemp
    A while back I remember seeing the attached spreadsheet. I'm assuming this would be a different procedure then what you mentioned above right? Is this spreadsheet even necessary or better than your method?
    Mods:
    445 RWHP/413 RWTQ
