Results 1 to 5 of 5
Thread: injectors maxed out?
    Aug 2021
    842
    What is the max duty cycle you can safely and reliably run? And, at what percent duty cycle do you need to be looking at getting bigger injectors? I would like to redline at 7k all day if I choose to do so.
    13,565
    I'd be stopping at around 90% or so.
    But from the screen shot you are running that engine pretty rich with a commanded AFR around 11.6, if you leaned that out your duty cycle would drop a good amount.
    Aug 2021
    842
    Good to know. What target AFR would you shoot for with a NA car at WOT? Somewhere around 12.8?
    13,565
    That really depends, so it's hard to say.
    If you're going to beat the piss out of it all the time then run it richer in my opinion. Like 12.3-12.5.
    Obviously using a dyno would be best but most don't have one. But going from a 11.6 to a 12.3 will free up a little duty cycle.
    Aug 2021
    842
    Hey man I appreciate the info.
