Results 1 to 12 of 12
Thread: Cold start problems on 05 GTO with 402
    Mar 2006
    Wichita, KS
    17
    Any suggestions from looking at my tune as to what I need to do to get my GTO to idle better when it is cold out, cold as in 40 and below.
    It's hard to keep running until it warms up.
    It's an SD tune.
    Mods are:
    403 ci
    Dart CNC heads
    246/250 636 cam
    11.96 static - 8.6 dynamic compression
    fast 90
    42 lb inj
    Thanks Chris
    05 GTO
    403ci LS2
    Dart CNC 225's
    TH400 - Chance converter
    10.75 @ 124mph na
    9.76 @ 141 on the spray
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Try these settings, your IFR table looks too high for your 42# injectors. Your VE tables needs a lot of work, as it is very spiky. Could you post a scan log showing the AFR?
    Russ Kemp
    Apr 2003
    Almost 2000 feet.
    7,876
    Also look over your IVT gain table. You can generally reduce the values in that table at cold start quite a bit as the engine is probably too rich.
    Just look over the startup coolant value on the IVT table and the MAP you are running to locate your idle point. Then about every 5-10 seconds of idling, the IVT temperature value goes up to the next line (guesstimate - as IVT isn't reported in the scanner) up to about 234 deg then it slows somewhat. Adding power will cause the IVT temperature value to increase quite a bit faster.
    If you are monitoring your wideband (you do have one right?) check to see that the AFR is at least in the 13's to low 14's at cold idle. If not, make changes, let the engine cool off completely and do it again. Cold idle is about the hardest adjustment to make as you get one shot before the engine warms up...
    Always Support Our Troops!
    Mar 2006
    Wichita, KS
    17
    Thanks guys, I'll take a look at that stuff. I know my VE table is pretty messy looking but it runs really good once it gets warmed up. I need to smooth it, I haven't done that since my last tweak to the ve tables.
    And yes I have a WB.
    Chris
    05 GTO
    403ci LS2
    Dart CNC 225's
    10.75 @ 124mph na
    Dec 2006
    Washington State
    96
    Thanks EC that was the table I have been looking for.
    Quote Originally Posted by EC_Tune
    Ellis
    Speed Secrets
    95 Z28 18* LTx
    95 Z28 LSx converion
    03 CCSB 4x4 D/A
    Apr 2003
    Almost 2000 feet.
    7,876
    Glad to help.
    Dec 2004
    Laurel, MD
    1,020
    EC, are you saying that IVT tables are actually working in E40 cars? i haven't seen any evidence of any sensors or stuff hooked up to intake valves in LS2's. i'm confused...
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    as per Chris "uses engine speed, manifold pressure, engine coolant temperature, spark advance, fuel ethanol percent and air/fuel ratio. its a complicated linear equation with coefficients etc. the result is then filtered in relation to intake airflow, ie. faster filtering for higher airflows."
    Dec 2004
    Laurel, MD
    1,020
    if they know it, why not post it?
    HP Tuners Support
    (foff667)
    28,268
    SE asked chris in the moderators section, chris gave him the answer & im passing it along to you
    I don't think it was specifically asked what it was or how it was calculated until now, but either way there ya go
    Dec 2004
    Laurel, MD
    1,020
    so where's the equation? did you forget to attach something?
    HP Tuners Support
    (foff667)
    28,268
    Chris is working on it, its not done yet...he's going to add it as an MPID
