Originally Posted by
itskeevenistic
Just need to know that I have the right idea for the tuning process on my LQ4, and I'm not looking for max performance, just reliable power.
I just did a cam swap, (212/218 112LSA), and I am going to start tuning once I get off work.
I've been looking everywhere for a "step by step" or at least a guideline that is kind of something like, "If you have *this* or did *this* then you will start by tuning *this*.
At that, even just something that says, "here is what order you should tune things in, and somethings can be done before or after the next or previous step"
So if I have the process correct, I added some RPM to help it idle, gave it a couple degrees in the idle RPMs, disabled COT and DFCO. About to flash and edit this post if I missed something or messed something up.
From here I would tune MAF and then VE correct? That's correct. If you still have the stock MAF and airbox, then your MAF will be close. You'll find that you'll have to remove fuel from the VE table at idle/low rpm, and add at upper rpm.
After those are dialed in I can finish the idle tuning right? Yes. Don't forget to adjust the min airflow table. It'll likely have to be increased by at least 20% in the higher temp areas.
And what about adding timing after I add the timing I took out for those tuning processes? I don't remove timing from the timing tables for tuning. I have found it to be more accurate to set the timing tables to something similar that I've already tuned. You'll be at a disadvantage here, but here's what I typically start with on a combo like yours. Around 20 degrees at idle will be close. At WOT, peak torque will be around 19-20 degrees at WOT (around 4000-4800) and 22-23 at upper rpm (4900-up). This will work nicely with 91 octane fuel. You can adjust a couple degrees up or down for whatever octane fuel that you run.
Basically I've got;
Get it idling
MAF Tuning
VE Tuning
Idle Tuning
Profit?
I already have a wideband installed so I can log that info and not seriously destroy something due to not knowing AFR. Outside of that its fair game.
I'm just looking for guidance, I've been scouring these forums for weeks now, reading, watching, re-reading, etc.
Here's the first startup tune for reference.
Anyways, I'm lost, I haven't found the answers that I'm looking for, or maybe I'm not understanding the ones I've found. Any help is appreciated and thank you for at least reading.
