Results 1 to 19 of 19
Thread: Still not going WOT
    Aug 2021
    842
    Still not going WOT
    I took the car out today to see how it is going to act. I feel like I have disabled the whole Torque Management section but apparently, I have overlooked something. I still cannot get it to go WOT. Any suggestions would be appreciated. WOT cutout.hplwotcutout.hpt
    Tuning Addict
    6,804
    Max torque vs individual gears - max those out unless your tyring to use them to control wheel spin / etc rate limit - set all but neutral and park to 100 / Fuel - Cutoff - accel threshold - 0 that table out
    Your going 100% in the log - right at the end of the pull
    ~Greg Huggins~
    Aug 2021
    842
    all changes have been made. I'll flash that in and see what she does tomorrow. I initially thought that I was getting knock due to the timing in my Idle Base table, but I didn't pick up any knock today.
    Separate silly question. On my MAF table, if it is reading -5.61 and i want to bring it down to -2. Is it just simple math there? Just add 3.61 at that particular Frequency? There is not a multiplier for the MAF correct?
    Guess I should've said, "Few silly questions." lol
    7,646
    Your MAF chart in the scanner is the amount of error in percent, not whole numbers to be added or subtracted. You need to multiply or multiply by 1/2.
    Aug 2021
    842
    Perfect! Thanks squirrel!
    Aug 2021
    842
    Went for a ride and she still don't want to act right. It appears she is being hateful, non-cooperative, and flat out resentful, so, I checked under the car to see if there were any "red" fluids and possibly a pattern from month to month.
    Any suggestions on trying to log something different that would tell me why I'm not being able to go past 4600rpm? 1.hpltqmgmtmaxed.hpt
    Tuning Addict
    6,804
    You sure your not just looking at the wrong tps pid? Because you are looking at a couple. Pedal and etc command are the two main ones unless your actually feeling something going on.
    ~Greg Huggins~
    Mar 2011
    Ripley, MS
    1,865
    Disable the Engine Oil Starvation TM and see if that fixes the issue. Why are all of the oil pressure DTC's disabled?
    Actually, there are several more DTC's that could be causing the issue as well. They need to be put back to stock.
    The oil temp and the oil pressure DTC's have been changed.
    In addition to that, P0685, P0690, P0865, P162B, P2548, U0073 DTCs have all been changed to No Error Reported for some reason. I would put them to stock until you diagnose the issue.
    Aug 2021
    842
    Kev, buddy i guess because i was sent a TOON and not a TUNE. LOL i'm so glad i purchased HPT so i never have to deal with that crap again. i am not very experienced with tuning but am super thankful for all you more experienced guys on this forum. Ill see if i can get all the DTC's put back stock. Thanks a ton!
    Aug 2021
    842
    GHuggins i may not have explained myself well. I can go full throttle but it keeps cutting out around 4600rpm like it's hitting the rev limiter. I cannot stay in the pedal. Sorry for the confusion.
    Tuning Addict
    6,804
    It's probably going to be like Kevin pointed out then. I've never seen anyone kill oil pressure test or dtc's, well I've seen one company do it, but they set all dtc's to no error. The dtc's may even correspond to oil temp - I didn't look at which ones were killed - you have some higher oil temp rev limiter settings set to 5000. Hopefully whomever just used hpt for tune editing and nothing in the background is changed. There are some other rev limiters in the calibration that completely kill the rev limiter that's not in hpt - for a reason, so I know with different settings those can be used to alter how quickly it kicks in.
    ~Greg Huggins~
    Aug 2021
    842
    currently pulling a DTC list from a stock 15 z28. Should i just follow suite with that list or will it vary some where im a swap vehicle? My oil pressure reading is taken care of by dakota digital guages and sensor if that makes a difference?
    Tuning Addict
    6,804
    Just put in the OE list. Depends on how altered the powertrain is.
    ~Greg Huggins~
    Aug 2021
    842
    Will do! FWIW, it's a 68 camaro. ls7 converted to wetsump with t56 magnum and ridetech 4-link suspension with 9" rear.
    Tuning Addict
    6,804
    After looking at the dtc's I'm pretty sure the problem was in the rev limiter sections that correspond with the dtc's - also not sure why he would have changed some of this stuff? This one should be more suited to your setup.
    ~Greg Huggins~
    Aug 2021
    842
    Hey thanks man. I will flash it in and report back when all this rain subsides.
    Aug 2021
    842
    Car hit 6k rpm!! Huggins, that may have done the trick! It did cut out at 6k but I believe I was getting into some knock. I'll see if I can get her lined out a little more now! Thanks a ton!!wotattempt.hpl
    Tuning Addict
    6,804
    There were some wheel speed limiters and oil temp limiters in your original that I'm pretty sure you were hitting - more precisely the wheel rev limiter. If anything this should be maxed out so it will default back to the regular rev limiter - AGAIN - not sure why the original tuner changed this? I'm assuming with this being a powertrain swap, you don't have abs or wheel speeds feeding data to the ecm, so was hitting a 40something limiter...
    ~Greg Huggins~
    Aug 2021
    842
    you are correct in your assumptions Sir. No abs or wheel speed sensors.
