I have a 2010 LS3 out of a 2010 camaro ss with a 15 pin 4L65 trans and a psi conversion harness all nestled into an 05 shortbox 2wd truck. I switched the ecm to an 08 tahoe e38 with an 09 silverado t42 tcm. Truck runs great and the trans is working but it is maxed out on line pressure and the tcc wont lockup due to the speedo in scanner always reading 158. Can someone please look at my tune and see if you can see anything that would fix this?Dave Lewis new ecm w new 09 tcm3 throttle changed to rpm speed changes.hpt
