Results 1 to 2 of 2
Thread: 13.5 compression E85 and 91 tune
    Tuner 3rdcoastpowersports's Avatar
    Dec 2012
    Loonie Bin
    59
    13.5 compression ratio LS7 that will run mostly on E85 but would like to be able to also run 91 if I cant get E85 when I need it.
    So the question is:
    Can I use a flex fuel sensor and run a high octane timing table for the E85 and then use the low octane timing table for the 91 octane?
    2006 E38 ECM is being used
    13,573
    The E38 should have a gas and alcohol spark correction table. So you can use those tables to add in spark based on the alcohol content in the tank.
    You can't make the high/low octane table work separately like you said.
