Results 1 to 5 of 5
Thread: TUN or fast learn?
    Apr 2012
    43
    TUN or fast learn?
    I had to get a T87 separate from the trans for my swap (no ECM or TCM included). Do I need to have the TCM flashed with the TUN on the sticker on the side of the 8L90 or can I just do a fast learn?
    Jul 2021
    7
    You will need to flash it with the proper TUN info.
    Advanced Tuner IARLLC's Avatar
    Aug 2016
    943
    Quote Originally Posted by jaketillmann86 View Post
    THAT!
    And then a fast learn.
    8L90s have enough shift issues when they are set up right....they can only be worse if not set up right.
    Apr 2012
    43
    Can HP tuners do that or is that a dealer only thing?
    Aug 2016
    943
    You just need a decent mechanic with an MDI and some knowledge. As long as the T87 has a compatible OS you can just run it but it will shift better if the solenoid info is flashed.
