Results 1 to 18 of 18
Thread: Tuning LS7 Wetsump Gen IV e38
    Tuner in Training c4love's Avatar
    Feb 2014
    Texas
    35
    Angry Tuning LS7 Wetsump Gen IV e38
    For the love of life I cant get this car to stay in open loop.... My O2s keep taking the wheel and I have tried everything I know to disable them can someone suggest what they fail to keep o2s from changing fuel trims.
    This is in a 2013 Camaro SS just finished the motor swap. I was able to do this on my e67 ecm but this e38 is giving me hell.
    Disclaimer I am very GREEN to tuning but am learning...
    TIA
    Chris
    Jan 2022
    40
    Do you have a current tune file you can share?
    Engine-Fuel-Oxy Sensors-Monitoring-O2 Readiness needs to be set higher or lower than what the engine will ever hit. I.E. max to 493 degrees F
    Aug 2009
    Calibrating
    3,373
    Let me know if I can help!! Depending on cam size, by I would run closed loop on that setup though
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Feb 2014
    Texas
    35
    Quote Originally Posted by Ben Charles View Post
    Im thinking I found it here just need to test tomorrow but im thinking the below settings should keep me in OL for MAF tuning. Fingers crossed..
    My next problem is I installed a 160 Tstat and I want to be able to turn my fans on eariler but sooniest I see I could turn them on at all is 192F seem high to me... Any ideas or suggestions or is having them come on at 192F ok?
    Feb 2014
    Texas
    35
    Quote Originally Posted by Jarrod.v View Post
    Thanks Jarrod - I think I may have that sorted will see tomorrow, now im trying to figure out how to get my cooling fans to come on eairler than 192F...
    Aug 2009
    Calibrating
    3,373
    The picture you posted above will do nothing to keep the car in OL
    14 Gen 5 Viper
    Feb 2014
    Texas
    35
    Thanks Ben for the reply. Mind sharing what you would set to put the car in OL? Attached is my current tune file.
    Aug 2009
    Calibrating
    3,373
    Just max out the ECT and time for Closed loop and it will stay in OL
    14 Gen 5 Viper
    Jul 2020
    VIC Australia
    1,160
    From memory, running the 2 bar custom OS gives you a few extra cells down as low as 160F.
    Feb 2014
    Texas
    35
    Thank you Ben really apperciate it will give this a go.
    Feb 2014
    Texas
    35
    Quote Originally Posted by hjtrbo View Post
    Sounds good Hjtrbo, except not sure how to set up a custom 2 bar? Sorry I am very GREEN to tuning as you can all see. But im taking suggestions and learning a little at a time.
    I did manage to get my car to idle today sitting in the driveway without stalls or overheating so progress is all im after dont need the car fully tuned race ready tomorrow, I would rather learn the process and understand what I am changing and why.
    Feb 2014
    Texas
    35
    Quote Originally Posted by c4love View Post
    Bingo! Thanks again Mr Ben. You da man sir.
    Jan 2022
    40
    lol thats what i said to do on the very first reply...
    Feb 2014
    Texas
    35
    Thanks Jarrod.v as well sir! Thank you ALL!! I will have many more NOOB quesitons just stay tuned See what I did there.
    Jan 2022
    40
    It's all good. I'm here constantly learning new things too. Between here and youtoube, we will all become experts though
    Feb 2014
    Texas
    35
    Exclamation
    Good Afternoon fellow tuners! So im in OL and MAF only i think - Took the car around the block and made it! but not before my car went into limp mode im guessing because it went SUPER Lean 3300Hz on the MAF. Is this something I just multiple by half on and rinse and repeat until I stop hitting limp mode?
    Attached is my log which fairly short and the tune I was running while logging. Thanks for any suggestions or help ALL!
    Chris
    Jan 2022
    40
    Literally had the same similar issue today except I am in SD only. Did your maro throw any codes? I generated a P0106 and P0068. Had some insight from others and suggested to raise a couple parameters. Check my post, and see if that helps. It's the one with the Help! Reduce Power lol
    Feb 2014
    Texas
    35
    I got a couple TB codes P1516, P2101, I have a 102mm TB Drive by wire ETB. So mine seems throttle body related. But no idea why or what I need to look at changing there...
