Results 1 to 5 of 5
Thread: L86 8L90 swap very rough idle and surging
    Apr 2012
    43
    I have the following hardware installed for an L86 8L90 swap into a 67 Camaro.
    L86 with: LT2 intake, Spectre CAI from 2016 SS Camaro, Speed Engineering (short) headers, 3" exhaust with X pipe
    8L90 stock
    Fuel System: Aeromotive 340 in tank pump, 30-90 adjustable fuel pressure regulator controlled by relay from FPCM signal wire
    Lots of surging at idle and boggs down really low at times. When throttle is depressed, RPMs hang at 2500-3000 and stay there before eventually going back down.
    I noticed that in the fuel system in my tune, FPCM is selected which doesnt seem right. Anything else Im missing that is off with the base tune, the tuner did for me?
    camaro tune.hpt
    Apr 2012
    43
    Quote Originally Posted by blackdog76 View Post
    8L90 stock
    camaro tune.hpt
    Log File
    log 2.13.hpl
    Tuning Addict
    6,802
    Change fpcm setting and see if timing comes back positive. Only thing I looked at so may have a lot of other things wrong causing the very negative timing and incorrect fueling.
    ~Greg Huggins~
    Apr 2012
    43
    will do, thanks
    Apr 2012
    43
    I did an idle clean and reset the fuel trims. Runs great now and no more hanging rpms.
